denso wires
Old Nov 13, 2007 | 09:46 PM
ks_yota's Avatar
denso wires
was looking to get some feedback on the denso wire set
http://sparkplugs.com/results_app.asp
want to go with the ngks but not lookin to spend that much
searched the forums and havent found anything on denso wires
Old Nov 13, 2007 | 09:53 PM
Jay351's Avatar
Denso is what toyota used from the factory if im not mistaken...
I got a set of NGK's from them
Old Nov 13, 2007 | 10:10 PM
ks_yota's Avatar
those are about 30$ and when i went to the dealer i was quoted for wires at 120$ or so. mybe they are the same? i got cap and rotor which were denso.
but how do you like the ngks? did it make any difference?
Old Nov 13, 2007 | 10:22 PM
thook's Avatar
I've learned recently brand is not so much the key as is what the cable core is made of. Carbon cores will be cheaper, but don't send as good of a spark and don't last nearly as long as a wire core. You'd be happier....rather the vehicle would....with wire core. They do cost more intitially, but not in the long run. So, look at how the cables are made before you decide on brand.
BTW, OEM Denso....from what I understand...is a carbon core. Manufacturers cut production costs where they can.
Old Nov 13, 2007 | 11:14 PM
Jay351's Avatar
well the dealer will mark up products pretty high. I got a NGK direct replacment o2 sensor for like 35 bucks. Every other auto store wanted 150+.
As for the wires, I havnt installed them yet. A friend had make a big order and I got him to buy me the wires. I have to make time to get up to his place and grab them. I will let you know if they make a big difference.
Old Nov 14, 2007 | 02:55 AM
Targetnut's Avatar
I can't recall ever seeing denso wires. although everything denso I've used is good.
factory wires are sumitomo, I believe. or maybe yazaki
NGK is very good as well.
Don't cheap out. get good parts.
krimsonone
Sep 13, 2024 09:33 AM
raptor510
Aug 19, 2015 02:15 PM
WellsR
12
Jul 31, 2015 03:27 PM
jjrbus
Jul 27, 2015 11:06 PM
Cbr954ryder
Jul 25, 2015 06:32 PM
