Defroster related to A/C Compressor?
Old 02-25-2012, 08:28 PM
Sin
Sin's Avatar
When I bought my truck, the A/C system wasn't working - so I'm thinking of removing the compressor, just cause.. But if I remember right, the compressor kicks on when you turn on the defroster? Is that correct?
I don't plan on fixing the a/c for awhile, just thought it might free up some space for starter work later on. Ideas?
Old 02-25-2012, 08:53 PM
justin_4runner's Avatar
yes when its on defrost it will kick on to help pull moister out of the inside, but if u are planning on fixing it at any time i would not pull it out cause air and moister getting into the system and having to replace other items then maybe a pump or where its leaking from that cause it not to work. it will dry out seals and could cause other problems from having the system open(rust)
Old 02-25-2012, 09:17 PM
Sin
Sin's Avatar
Alright thanks, that's the info I needed right there.
Old 02-25-2012, 09:32 PM
James Woods's Avatar
You dont need to worry about rust inside of your A/C system, the A/C system is made up of aluminum which does not rust, the moisture inside of an A/C system mixes with the refrigerant and oils and makes a corrosive acid and sludge that ruins a system.
The A/C does come on with the defrost as stated by Justin to remove the moisture in the air inside your truck, your defrost will still work without A/C, it will just take a little longer. Besides you live in Arizona, who wouldn't want A/C there.
Old 02-25-2012, 10:17 PM
Sin
Sin's Avatar
It'll be fixed eventually, just can't afford it now and YES a/c is a must have in Southern AZ - my daily driver has a/c
Old 02-26-2012, 06:43 AM
Marc's Avatar
The A/C DOES not come on with the defrost unless the A/C button is engaged.
Some vehicles do that but not 2cnd gens.
Old 02-26-2012, 09:57 AM
Sin
Sin's Avatar
kawazx636
10-06-2021 03:03 PM
zytra
01-24-2019 03:16 PM
Badlander
10-10-2015 08:05 PM
zombie_barbarossa
10-02-2015 10:54 PM
Quick Reply: Defroster related to A/C Compressor?
