dash lights - brake - battery - at oil temp
Old 05-28-2013, 04:59 PM
popthree's Avatar
hello
i have a 1993 toyota 4x4 3.0L with Automatic trans.
this is my sons truck. he first mentioned that the brake light was coming on sometimes. i figured it was just a switch.
last weekend i helped him change the oil on the truck. after we finished i started it up and noticed the battery, brake & AT oil temp ight all on.
he said up until right then, he had never noticed the other 2 lights.. just the brake light.
this AT oil temp light is on all the time, even when the vehicle has just been started after sitting overnight. i did check the fluid and it is at the correct hot level.
i searched the forum and found a lot of info about the brake & battery light being on all the time and that it is my alternator going out.
is it possible that the AT oil light can also be a symptom of the failing alternator?
thank you
Old 05-29-2013, 04:02 PM
popthree's Avatar
bump
Old 05-29-2013, 04:38 PM
rustypigeon's Avatar
Yes, the AT oil light comes on with a bad alternator. I can about guarantee that the alternator is your problem.
Old 05-29-2013, 04:42 PM
popthree's Avatar
great to hear that. thank you very much for the reply.
Old 05-29-2013, 04:48 PM
No problem. Most of the time, the alternator brushes are the culprit. You can buy the brushes for a couple of dollars, or you can buy the brushes pre-soldered into the holder for about $15-$20.
06-01-2021 01:51 PM
Avenged
07-09-2015 07:55 AM
bryan34w
07-06-2015 05:53 PM
colinmil
07-06-2015 04:03 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: dash lights - brake - battery - at oil temp
