custom air filter setup
Old 02-01-2009, 09:14 PM
xzyragon's Avatar
i don't know if i can pass smog with the setup now, but I passed it in september, so i got a while
anyway, went to pep boys and picked up a spectre oe air filter for 28 bucks and an extension pipe for 10 bucks, pieced it together along with other parts I had, and propped it up with an extra AC bracket...
Old 02-01-2009, 09:18 PM
xjdubber's Avatar
How would an air filter affect the results in a smog test at all?
Old 02-01-2009, 09:21 PM
xzyragon's Avatar
ionno, but thats what the guy at pep boys told me...
Old 02-01-2009, 09:24 PM
myyota's Avatar
Ok, maybe im missing something, but were is the AFM ?.
Old 02-01-2009, 09:28 PM
xzyragon's Avatar
i kinda skipped that. busted from the crash
Old 02-01-2009, 09:30 PM
Elton's Avatar
soo how does it run ?
Old 02-01-2009, 09:31 PM
myyota's Avatar
So how is your truck even running with out it ?.
Old 02-01-2009, 09:36 PM
iamsuperbleeder's Avatar
you haven't tried to start it yet, have you...
Old 02-01-2009, 09:38 PM
xzyragon's Avatar
last i heard, u dont need it, cuz it only optimizes cold / hot air intake. Im not gonna pay the money to get one atm.
@ elton, i have no idea how it runs cuz its still on jack stands and i haven't finished the body repairs / radiator yet
xzyragon's Avatar
it starts, i just can't run it for too long without coolant fluid
Old 02-01-2009, 09:40 PM
normally without the AFM installed, it will start for a second, but wont run for more than 1 or 2 seconds...
when the motor's running, the AFM sends a signal back to the ECU to run the fuel pump. without it so much as plugged in, the fuel flow stops and the truck dies. that is unless you bypass that and do some wire splicing...
that's why everyone was commenting about it...
Old 02-01-2009, 09:41 PM
xzyragon's Avatar
it runs for at least 10 seconds, i dont wanna overheat the engine tho
Old 02-01-2009, 09:43 PM
huh...
ok, I'll just stop while I'm ahead then...
but I think you'll run into some issues about that later on...
don't say I didn't warn you
if it was so easy as to just leave the AFM out, I wouldn't have went through hell and back for my setup...
Old 02-01-2009, 09:47 PM
xzyragon's Avatar
im sure that ill run into problems, but logically, it shouldn't matter whether its in or not. However, from previous problems i have encountered, many of the fixes do not seem all that logical....
oh well
Old 02-01-2009, 09:49 PM
874runnersr5's Avatar
haha, subscribed..
Old 02-01-2009, 10:11 PM
1989toy4wd's Avatar
Yeah you need the AFM, it tells the computer how much fuel to add along with some other sensors, when mine went out the truck woundnt start, it would just crank. If its running then something wierd is going on!!
Old 02-01-2009, 10:18 PM
xzyragon's Avatar
maybe my truck is special
Old 02-01-2009, 11:05 PM
space-junk's Avatar
are you in california? i know in califronia, you MUST have the OE air intake to pass the visual test during emissions, OR a C.A.R.B. sticker saying that its legal...
Old 02-01-2009, 11:18 PM
toyota4x4907's Avatar
Dude, no need for coolant. It won't overheat with that setup. I don't understand why other people don't run it like that....
Old 02-02-2009, 12:37 PM
coolant, oil, hell fuel too, you don't need any of that mess, why should you need an AFM?
Quick Reply: custom air filter setup
