cruise control switch
Old 02-07-2011, 10:52 AM
kharris's Avatar
where do you turn on cruise control at? i have an 86 runner but my manual is for a 87. the manual shows a button somewhere on the dash, but i cant find one on my 86. i have the selector in mine that says set resume coast and accelerate. there seems to be a button at the end of the column but nothing happens when i push it.any help would be great, and thanks
Old 02-07-2011, 11:22 AM
kiyobrown's Avatar
on the dash, right side of the steering column. button that says cruise and a bigger green plastic lense, which is a courtesy light to see the ignition.
the space on the bottom right is where it sits.
Old 02-07-2011, 12:52 PM
phildelfino's Avatar
it's useless, by the way.
Old 02-07-2011, 12:56 PM
kiyobrown's Avatar
mine works just fine. only problem is the whole "its a 5 speed, so cannot downshift" But running down the freeway for me it's fine.
Old 02-07-2011, 01:14 PM
kharris's Avatar
mine does not have the button your talking about to the right of the steering wheel. may be i dont have cruise control, but why do i have the column on the left of the steering wheel.
Old 02-07-2011, 01:18 PM
kiyobrown's Avatar
someone swapped the column bc a switch wasn't working right?? who knows.
Old 02-07-2011, 01:24 PM
Philbert's Avatar
That's my vote. I replaced mine years ago because the headlights would sometimes just cut out. Of course, mine had CC before so it all works together. but Jason's probably right - someone bought a used replacement and it happened to come with CC.
Time to retrofit!
Old 02-07-2011, 01:25 PM
kiyobrown's Avatar
lol. If you look under the hood and you have the servo next to the clutch master..... then someone just stole your switch.
Old 02-07-2011, 01:48 PM
barrel roll's Avatar
Well... I don't have factory cruise control!
Old 02-07-2011, 03:34 PM
kharris's Avatar
at first i thought the same thing. but there are two rods coming off the left side of the steering column. one for the head lights and turn signals, and the other one for cruise control. so why put one in for cruise control if there is no cruise control. you wouldnt swap a switch in if one isnt needed.
rusty904
03-27-2017 05:20 PM
mussy01
12-13-2016 08:20 PM
Badlander
06-20-2016 07:20 AM
Runner4Luke
08-12-2015 06:42 AM
JAMGarcia
7
07-31-2015 11:46 PM
Quick Reply: cruise control switch
