Cross threaded spark plug
Old 07-10-2009, 07:48 PM
TheRival's Avatar
Originally Posted by DupermanDave
But it still happens. If he created a new thread, he would have gotten the "do a search" routine.
quoted for truth
Old 07-10-2009, 07:53 PM
Jay351's Avatar
I agree. He did search and found a thread that was relevant to his problem. If he made a new thread he wouldve been told to search....
Just chill yo
Old 07-10-2009, 08:08 PM
CyMoN's Avatar
the reason the 4th cylinder gets cross threaded is most people do not notice that the spark plug is pointing towards the fire wall or the brake MC not straight out.
if you look closely the number one plug points toward the front of the truck slightly, two and three point toward each other and 4 points toward the back of the truck
if you try to thread the #4 in with a long extension the extension will set against the fire wall and not let the plug go in at the angle like it is supposed to.
Old 07-10-2009, 08:32 PM
camo31_10.50's Avatar
we found a little black thing that i think is called a thread chaser..all the shavings it created were brought OUT by the little black thing..lol
it has 4 groves in the side of it to grab the loose material and brought it out...of course mine got cross-threaded and then we did that..and a few months later i spun my #2 rod bearing..lol and then we had to take the head off anyway..
it wasnt hurting anything being in there funny...it still ran like a champ..we just didnt like it being like that..lol
Old 03-15-2010, 04:25 PM
  #25
Jeremy11's Avatar
Bringing an old thread back. Just got back to replacing my spark plugs and turns out my #2 cylinder is cross threaded. What is the best way to go about re-threading it?
I have a 3.0 V6
Old 03-15-2010, 08:59 PM
  #26
Jay351's Avatar
It depends how bad it is. If its not bad you can get away (most times) with carefully chasing the threads.
If its bad then it must be drilled and heli-coiled. If the latter is needed use Jason (green93)'s method.
I got away with chasing the threads.
Just be thankfull its not the number 5 or 6 cyl..
Old 03-15-2010, 09:27 PM
  #27
get a thread chaser..it's what i used on my number 4 hole on my 22r and it worked perfectly fine...
but don't try to use a magnet to get the shavings out.......aluminum heads weirdos lol
Old 03-16-2010, 10:56 AM
  #28
Jeremy11's Avatar
Got a thread chaser, oiled it up a lil and it worked perfect after removing my alternator and air box to get the right angle. And after i thought id never get that spark plug back in i ot it!
Old 03-16-2010, 06:32 PM
  #29
dfarr67's Avatar
JB Weld the bugger in
Old 12-04-2014, 04:36 PM
  #30
Tugboat's Avatar
Reviving an old thread once again but I found it helpful so I thought I'd add to it.
If you reference the Denso spark plug specs chart in the link below you find out the thread for the W16EXR-U plug for the 22re is a 14 x 20.6
http://www.globaldenso.com/en/produc...ket/plug/spec/
Now I just need to find an appropriate thread chaser to try and fix my #4...
Old 12-04-2014, 06:07 PM
  #31
Odin's Avatar
Lisle 20020 fit my 22R-E
Amazon.com: Lisle 20020 Limited Access Spark Plug: Automotive Amazon.com: Lisle 20020 Limited Access Spark Plug: Automotive
A cheaper one is available and easier to find but it isn't quite as nice. WILMAR/Performance Tool W80537
Amazon.com: Wilmar W80537 Spark Plug Hole Chaser, 14mm: Automotive Amazon.com: Wilmar W80537 Spark Plug Hole Chaser, 14mm: Automotive
Reference post#7
https://www.yotatech.com/forums/f116.../#post52231861
Old 12-05-2014, 08:47 AM
  #32
oldmansimek's Avatar
Helicoil M14 X 1.25 Sav-A-Thread Kit - 5334-14. This kit works just fine have done several of these never had a problem. Load the tap up with grease and only go a turn or so at a time take it out and clean it, then use a good vacuum.
Old 12-05-2014, 09:05 AM
  #33
Odin's Avatar
The big problem here
Exactly,
Use a small piece of snugly fitting hose over the head of the spark plug and turn the spark plug into the cylinder by twisting the hose and letting the threads in the spark plug find their way. There's no way of providing enough torque to start the spark plug crooked by doing it this way.
It's actually best to use the tubing to remove the plug from the last few threads too. It sounds stupid but some people actually manage to mess up the last few threads when they try to remove the spark plugs using the socket, extension, and ratchet.
Old 12-05-2014, 10:14 PM
  #34
bimmertech89's Avatar
Bringing threads that are messed up is a tricky situation. I'd watch some YouTube vids if it's your first time and be very careful and go slow
Eggslinger
06-08-2019 03:32 PM
raptor510
02-17-2017 07:11 AM
Alex Bessinger
08-31-2015 09:17 AM
cars-guy
07-11-2015 07:51 PM
88runnergomas
07-09-2015 01:12 PM
Quick Reply: Cross threaded spark plug
