crankshaft seal question
Old 10-20-2008, 03:01 PM
kauaiTOY's Avatar
hey guys, my friend took his truck to a mechanic who told him that if he replaced the crankshaft seal, it would blow out right after he changed it. is there really a problem like this? the motor is a built 22r bottom with a mild 20r head and it is fairly new. i have never heard of this before and i have been working on toyotas for a few years.
Old 10-20-2008, 03:36 PM
Beaniam's Avatar
possibly if his harmonic balancer has a groove worn in it. if so then it needs to be sleeved or replaced with a different depth seal or just replace the balancer. I bought a new one off ebay for $65
Old 10-20-2008, 07:15 PM
Pistonman's Avatar
Ask the mechanic why it will blow out again.
Is the PCV system working correctly?
Is the engine developing too much crankcase pressure?
There are many reasons it could do this, and fixes for all of them.
Old 10-20-2008, 07:22 PM
86Toyrunna's Avatar
well yes there are reasons to cause this... BUT the biggest one i can think of is the BS factor.. sounds like the mechanic might be tryin to make some easy $$$...front main on a 22 is a walk in the park..just time consuming
Old 10-20-2008, 07:48 PM
jason191918's Avatar
Front or rear seal? Not that it really matters...
He may be BS'in, talking about positive pressure, or a groove.
pressure=PCV
groove=sleeve
BS=2x4
Old 10-21-2008, 09:01 PM
kauai808's Avatar
Ive never heard of such a thing. why would it blow right after he changes it. if thats the situation then it would blow right now
Old 10-21-2008, 09:13 PM
abecedarian's Avatar
if it's not blown right now then why does your friend need to change it?
Old 10-22-2008, 03:45 AM
4xJedi's Avatar
By 'blowing out' again I'm sure he means it continues to leak. If this is the front seal then it's because there is a groove on the seal mating surface of the crank pulley (as someone already mentioned).
Go to Pep Boys and buy a Felpro Timing Cover gasket set for $20. This has a Speedy Sleeve in the kit and is cheaper than buying a Speedy Sleeve seperate. The sleeve will cover the groove and give your seal a new surface to ride on.
Old 10-24-2008, 04:30 PM
kauaiTOY's Avatar
ya my friend doesnt no really much about his own truck, so i couldnt really get exactly what he was saying. he said something about compression in 1, 2 and 4 but i really didnt get it. i should just call the mechanic myself.
Old 10-24-2008, 04:41 PM
Bigblock's Avatar
That compression has to go somewhere if the rings dont seal.Get a second opinion!
Bigblock
jasonty
41
12-23-2018 01:00 PM
colasurdo
07-16-2015 11:32 AM
Iceman4193
07-15-2015 04:48 PM
andrewtexas123
07-14-2015 04:29 AM
Quick Reply: crankshaft seal question
