Coolant leak from Head Bolt and Water Outlet? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-18-2007, 08:36 AM   #1 (permalink)
I just picked up a clean 95 4Runner, 2WD, Auto, 120K on the ODO.
According to the service records, the latest one stated that there was a coolant leak from the Head Bolt and Water Outlet. Anyone know where these locations are and whats involved with the repair?
I still need to confirm the amount of leak, which I think is pretty small for now.
Thanks!
Nuckaman is offline
Old 10-18-2007, 08:54 AM   #2 (permalink)
GSGALLANT's Avatar
If you've got coolant leaking out at a headbolt, then unfortunately it's leaking past your headgasket to get into the bolt hole. Were the headgaskets ever replaced on your truck? If not, there was a recall several years ago (assuming you have the 3.0L).
Some people have had success in getting Toyota to replace the H.G. even this late in the game if they hadn't been done already. If they've been done once under the recall, you're on your own for the repair, though. It's quite a lengthy job to replace the headgaskets.
The water outlet is an easy fix. It's where the top rad hose connects to the top front of the engine. You just use FIPG (form in place gasket... just in case you don't already know that), to seal that. You'll have to drain the rad (at least down below the level of the water outlet), remove the water outlet, clean both sealing surfaces well, apply new FIPG, then re-assemble it.
I like to use "The Right Stuff" gasket maker by permatex. It's compatible with all the fluids on your vehicle, and you can re-fill your system almost immediately after you re-assemble the components (I usually wait 15 minutes or so just to be sure.)
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears
TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires.
2004 Camry LE - stock (and will stay that way)
1993 4Runner has been sold
GSGALLANT is offline
Old 10-18-2007, 12:10 PM   #3 (permalink)
Thanks for the response back.
Yeah, I figured it was a head gasket problem. I believe the original gasket was replaced by a indepentant mechanic years ago because it blew on it's own. I'm on my own on this one I believe.
What is my typical borrowed time on a leaking head bolt, providing it's a minor leak? I understand it is something I need to fix as soon as I can.
Nuckaman is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
22re - head gasket leak w/ no water/oil mix?? mochester 86-95 Trucks & 4Runners 8 06-17-2007 03:55 PM
Do You Need Distilled Water For The Coolant? jim628 95.5-2004 Tacomas & 96-2002 4Runners 25 05-18-2007 03:58 PM
3vze water outlet question the_supernerd 86-95 Trucks & 4Runners 3 01-22-2007 09:09 AM
coolant in water..again... toywheelin05 General Vehicle Related Topics (Non Year Related) 5 03-12-2006 11:55 AM
Coolant leak... rpeAMP 95.5-2004 Tacomas & 96-2002 4Runners 4 03-13-2003 07:52 PM
2009 InternetBrands, Inc.
