Coolant on Belts - 22RE - How to clean?
Old 10-28-2014, 10:52 AM
WildCard22RE's Avatar
I got some coolant on my belts, and now one of them starts squealing like crazy after a few minutes of idling.
What is the best way to clean them off? I'd be stoked if I could clean them without removing them.
Thanks a lot for the help here and before guys!!!
Old 10-28-2014, 10:55 AM
JasonYota's Avatar
Water? Do they have the correct tension on them? Good time to replace them now
Old 10-28-2014, 12:03 PM
anndel's Avatar
Like JasonYota says, shoot 'em with water and retighten them. do they look frail and cracking? Then replace them.
Old 10-28-2014, 01:28 PM
Shootin' 'em with water seems to have done the trick.
Turned out to just be the Power Steering Belt making noise.
It was weird: at first spraying it with water would only make it go away for 30 seconds to a minute.
Got fed up and closed the hood after spraying it several times and the noise coming back (although quieter) and after a minute the squealing went away and stayed away -- for now, fingers crossed!
Thanks for the voodoo yotatech assist guys!!!
Old 10-28-2014, 03:22 PM
highonpottery's Avatar
fwiw, belt dressing actually works quite well on belts. if you get dried on coolant it takes a bit more effort to remove than just a spray of water.
Old 10-29-2014, 04:52 PM
Yeah they're still making a bit of noise when the engine's warming up, but it's pretty quiet and goes away after driving for a bit.
I'm averse to the idea of belt dressing 'cause I don't like the idea of something sticky collecting and holding onto dirt and grime over time.
I've read that soap's not good for belts, but would that work? Spraying it with some soapy water?
Anyone solved with this problem before??
Old 10-30-2014, 05:33 AM
Badger62811's Avatar
Buy a new belt. You can get them for literally a couple bucks online.
the1998sr5
15
07-14-2020 08:35 PM
jasonty
41
12-23-2018 01:00 PM
Doug4320
03-24-2018 10:11 PM
09-04-2015 09:27 AM
ryerye13
07-14-2015 08:27 AM
Quick Reply: Coolant on Belts - 22RE - How to clean?
