compression testing procedure?
I did a comresssion test tonight on my 22re with a borrowed tester. I never did this before so I just did the following.
It was a snap-on tester and there was various hose fittings for different size spark plugs. I found the right size, but it did not have the valve core in it, some had the core in and some didn't.
So what I did was just watched the gauge jump up and down as the engine was turned over. I was getting 118psi one one cylinder and 120+ on all the others.
Should I have installed a valve core from one of the others hose fittings? It seems like that would just keep increasing the pressure in the gauge with each stroke?
What is the correct procedure for testing?
Basic procedure for compression testing is to warm up the engine, remove the plugs, attach the guage, fully open the throttle late and turn the engine over about 5 times. I've never noticed if they have a valve core or not.
And the specs for a 89-95 22RE are:
Normal - 171 psi
Minimum - 142 psi
Max variation between cylinders - 14 psi
So if you're really getting around 120 then that's low.
Normal - 171 psi
Minimum - 142 psi
it wont matter since, you should disable the ignition system and the fuel system, by pulling the wire on the distributor and pulling the fuel pump fuse.
also in the service manual they recommend dropping a few drops of oil in the cylinder if the compression in a little low and/or if the truck has been sitting, you should have the engine warm (not hot) when you do this too.
From the 93 truck FSM, 22re engine:
http://personal.utulsa.edu/~nathan-b.../6compress.pdf
Definately put the pin in. I have the same tester too.
MAKE SURE the coil wire is disconnected COMPLETELY. While doing some electrical tests, I removed only one end and the tip was close enough to the coil that the damned thing still started.
justdifferentials
14
06-11-2017 08:36 PM
runnermedic
13
09-21-2015 05:20 PM
_Nicco_
09-21-2015 03:06 PM
zz_denis
09-06-2015 03:43 PM
