cold start injector
Old 01-03-2007, 10:02 PM
ELD
ELD's Avatar
cold start injector
Is there anyway to test the cold start injector or sensor? My fuel mileage drops from 16mpg in the summer down to 10mpg when it gets cold out.
Also have a problem now with the truck not wanting to start after it sets for 20 min. or so after driving it. When does start it runs like it is flooded out.
'93 V6 auto truck
Old 01-04-2007, 05:16 AM
4Hummer's Avatar
Problem isn't going to be your Cold Start Injector or the CSI Temp Switch.
The Cold Start injector Only fires when the engine is A: Being turned over, and B: its Cold outside.
Old 01-04-2007, 05:33 AM
mt_goat's Avatar
'93 V6 auto truck
From the 93 truck FSM:
http://personal.utulsa.edu/~nathan-b...88coldstar.pdf
I've heard that they can get stuck on.
Old 01-04-2007, 03:46 PM
kpaxfaq's Avatar
i had those exact symptoms and it was my cold start injector, got it replaced and it runs like new again
Old 01-05-2007, 11:31 AM
ELD
ELD's Avatar
kpaxfaq,did your fuel mileage increase?
Old 01-05-2007, 01:14 PM
dcg9381's Avatar
If you suspect the cold start injector doing something funky, simply pull the connector, drive for a tank of gas, check mileage.
Old 01-05-2007, 02:11 PM
mt_goat's Avatar
If the injector was stuck open isn't it posssible it would still spray in fuel with the wire disconnected?
Old 01-05-2007, 06:05 PM
GT88Yota's Avatar
You could try pulling it and cleaning it with some sort of solvent to dissolve the buildup. Sure is cheaper then replacing it.
Old 01-05-2007, 06:26 PM
Targetnut's Avatar
You can remove the cold start injector and connect it to it's fuel pipe backwards. turn the key on and jump FP to +B in the diagnostic connector to run the fuel pump and see if the injector leaks. then you can energize the injector by jumping power and ground to it to check the spray pattern. Be careful to make the final connections to energize it away from the injector because spraying fuel and sparks can be a problem. then you can connect a test light across the harness connector and crank the engine from cold. the light should come on for a short duration which epends on the ambient temperature.
Old 01-07-2007, 10:32 PM
ELD
ELD's Avatar
I did all the checks except for the test light to see how long the injector fires. Everything checked out within the ranges. I diconnected the wire going to the injector to see if it makes a difference and of course the temp. is now colder than it has been in awhile. Disconnecting the wire sure does make it difficult to get started up (duh!!) but seems to help with the shut it down for 20 min. and start it back up issue.
I guess I need to check the sensor after I run it and it has been shut off for awhile.
Anything else to check????
BushPig
10-29-2022 06:26 AM
bigjstang
08-25-2021 12:41 AM
steve miller
10-10-2015 01:40 AM
Huntingtruckcletus
07-08-2015 05:26 PM
karbin
07-05-2015 11:37 PM
Quick Reply: cold start injector
