| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Code 41
__________________
Got a PDA? Stop on by!!! www.abfnet.com Last edited by ctcost; 09-03-2008 at 04:13 PM. |
#2 (permalink) |
PS did a search and came up with alot closely related but nothing exact so far. Thanks in advance guys for a link.
__________________
Got a PDA? Stop on by!!! www.abfnet.com Last edited by ctcost; 09-03-2008 at 04:11 PM. |
#3 (permalink) | |
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
41 is the Throttle Position Sensor signal... not that there's a short in the TPS signal. Anyways, even if there was a short in the TPS signal it is not likely ONE injector is gonna muff up the TPS since all injectors are wired and fire at the same time.
When in doubt- follow the codes........ ![]() Have some fun: http://4crawler.com/4x4/CheapTricks/TPS/index.shtml
__________________
Quote:
Insomnia: it's a way of life.
#4 (permalink) | |
Hmmm K, Got this
Quote:
Guess he's not such an expert. Guess I'll change out the TPS and adjust first as I have another. Thanks for the thoughts!
__________________
Got a PDA? Stop on by!!! www.abfnet.com Last edited by ctcost; 09-03-2008 at 09:03 PM. |
#5 (permalink) | |
well, whatever.
before you go too far, realize that an open could be a total loss of signal or a value much higher than expected, and a short could be a value much lower than the ECU expected.
It won't always be the absolute open or short. I gave you a link to help you test it, and you don't seem to care, so do what you're going to do.
__________________
#6 (permalink) |
Know that link well...Said...THANKS! LOL
I just want to get this done in the shortest amount of time possible and was hoping for a miracle answer. For the most part these trucks are a joy to work on. Except when it comes to engine stuff/ Damned thing needs to be replaced with a 350.
__________________
Got a PDA? Stop on by!!! www.abfnet.com |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| code 25 and 26? | doubledizzle | 86-95 Trucks & 4Runners | 2 | 02-06-2008 07:44 PM |
| 94 Toyota 4WD - Code 71 / Code 25 | mmunoa | 86-95 Trucks & 4Runners | 2 | 02-22-2006 06:50 PM |
| code 13 and code 14(ignition signal and rpm) | 22REFORME | 86-95 Trucks & 4Runners | 8 | 01-24-2006 11:41 AM |
| Code 22? | rpeAMP | Maintenance & Repair Archives | 2 | 05-17-2005 08:23 PM |
| Code Help! | sandtrx | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 05-07-2005 10:26 PM |
