Clutch problems
Clutch problems
1986 toyota 4x4 problems. Heres the problem when i press the clutch down and let off it releases at floor. I took off the slave cylinder it was good I going to try bleeding the line. The clutch is almost new
New throw out bearing? Make sure that was installed correctly, if you did the repair or a shop. If it was the shop that did it, I would take it back to them. But good start on the diagnosis. If bleeding the line doesnt help, you might ned to replace the clutch slave and then bleed it.
Staff
Is it a parts store brand? I have had problems of them not having the correct length of push rod in the slave cylinder. Compare it to your old one.
the1998sr5
15
07-14-2020 08:35 PM
the1998sr5
07-16-2015 06:20 AM
