Cluster board switch
Old 08-15-2014, 05:36 PM
Crazy_Guy97's Avatar
I have a 1987 Toyota 4x4 5 speed. That has no rpm cluster. I was wondering what would it require to switch clusters boards? Take mine out and put a cluster board that has a rpm cluster.
Old 08-15-2014, 05:41 PM
mct75's Avatar
You're looking for the "SR5 cluster" Lots of good guides out there.
2 things though, you'll have to run the line for the tachometer and you'll have to replace the oil pressure sender. Both are easy.
Old 08-15-2014, 05:43 PM
^^ Explain more . How much would one cost me ?
Old 08-15-2014, 05:46 PM
mct75's Avatar
https://www.yotatech.com/forums/f116...w-pics-179106/
That's a good guide. It's for the 89-95 cluster but it all works the same.
They go anywhere from 75 bucks to 200 for a real nice one. Just make sure you swap that oil sender first.
Old 08-15-2014, 06:13 PM
What is a oil sender and where do I run the tachometer line?
Old 08-15-2014, 06:16 PM
JasonYota's Avatar
Did you follow the link that's posted above? There are many write ups on this, plenty of information
Old 08-15-2014, 08:03 PM
Gamma_Hugo's Avatar
you run the tach wire from the negative wire on the ignition coil to the "P" screw in the back of the cluster panel on the tach side. If you're truck is running a 22RE then you might have to adjust the resistance on the tach using a multimeter.
Old 08-16-2014, 08:29 AM
22 R engine
Old 08-16-2014, 08:57 AM
Gamma_Hugo's Avatar
It's the same procedure.
Old 08-16-2014, 11:45 AM
Robert m's Avatar
You've been around here for a few months and don't know to search for things? look up gauge swap or cluster swap.
Old 08-16-2014, 12:24 PM
Nervo19's Avatar
http://lmgtfy.com/?q=Toyota+22R+SR5+cluster+swap
^^^^Ten pages of results. Have fun reading. To get the cluster check eBay or contact a seller on here. You can use one out of a 22RE 84-89 4Runner or 84-88 pickup. As someone said you have to run a little wire to the back of the cluster for a 22R. You can even use one from a 3.0 6 cylinder but it will require recalibrating it.
Daenerysdad
10-01-2015 07:33 PM
runnermedic
13
09-21-2015 05:20 PM
imhousing
09-10-2015 02:04 PM
Rawwdz
09-06-2015 09:03 PM
mirabile4runner
09-03-2015 07:15 AM
Quick Reply: Cluster board switch
