Cleaning pistons...ideas?
Old 09-09-2009, 06:31 PM
9o7yota's Avatar
So before i put my pistons back in...of course i have to do the pin bushings and bearings and rings...i know to use part of the old rings to clean the ring bases...but what about the side of the piston...theres pretty much carbon built up around the entire circumference on almost all of them... in between the rings and down to the oil rings. plus the tops of course...how should i clean the sides? let alone the top?
Old 09-09-2009, 06:37 PM
iamsuperbleeder's Avatar
use an old ring to clean out the ring grooves
for the top, I know you can use a scotchbright pad, but I'm not sure about using that on the sides
DON'T USE A SCAPER OR FLAT-EDGE RAZOR THOUGH, THAT'S A NO-NO FOR SURE!!!
I didn't even bother during my rebuild... for the price, I just put in new ones from engnbldr
Old 09-09-2009, 06:40 PM
abecedarian's Avatar
brass wire wheel and lye (hot) (or oven cleaner- just make sure to follow the directions) for those hard to clean things.
Old 09-09-2009, 06:49 PM
9o7yota's Avatar
what about a brash brush? i have that.. and brake cleaner haha...
Old 09-09-2009, 06:51 PM
eh, I don't know that I'd want to use a wire wheel on the skirts of the pistons...
the tops either...
the FSM says not even to use a wire brush!
Old 09-09-2009, 06:54 PM
9o7yota's Avatar
yeah, i was trying to use brake cleaner and rags...but thats just wasted time....my bud said to get some diesel gas and soak the piston heads in that for a while...would that work?
Old 09-09-2009, 06:55 PM
eh, I guess you can use a gasket scraper on the top anyhow... but I'd be VERY careful...
Old 09-09-2009, 06:56 PM
Brass is one of the softest metal alloys. Works great for cleaning other metals... when used as a wire wheel.
Old 09-09-2009, 06:58 PM
9o7yota's Avatar
they still dont have a picture or something specific for the sides... whats the solvent?
Old 09-09-2009, 07:37 PM
I think I said:
Originally Posted by abecedarian
...<snip> lye (hot) (or oven cleaner- just make sure to follow the directions) for those hard to clean things.
Blamalam
03-12-2022 07:34 AM
jasonty
41
12-23-2018 01:00 PM
87toy pickup
09-07-2015 06:42 PM
djohnson13
09-04-2015 12:35 PM
09-04-2015 09:27 AM
Quick Reply: Cleaning pistons...ideas?
