check engine light help
Old 01-11-2008, 08:14 PM
619yota's Avatar
i have a 93 3.0 pick up that has a check engine light. the code according to my chiltons manual is a code 71 for the egr. does anyone have any suggestions how to test this or what the problem might be.
Old 01-11-2008, 08:25 PM
toytech76's Avatar
Could be a vacuum leak in one of the hoses, could be the modulator, could be a plugged egr port, if it has the temp sensor it could be bad or could be the valve itself. Lots of different part for the egr system. You should probably have someone diag it for you. Take it to a reputable shop
Old 01-12-2008, 06:08 PM
Georgiadave's Avatar
Look on the sticky for this site, there is a factory manual there. There is a trouble shooting diagram and procedure for code 71. I agree the problem is probably just a vaccum hose, you can diagnose this code yourself. Don't just start replacing parts, some of them are well over $100, and may not fix the problem.
Also , there are many threads on code 71 on this site. They will give you a feel for the problem.
Good luck with this.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
Kalihi,HI
07-09-2015 04:29 PM
God's Bounty Hunter
07-08-2015 12:54 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: check engine light help
