YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-18-2008, 10:32 AM   #1 (permalink)
93ToyKid's Avatar
Send a message via AIM to 93ToyKid
Charging light/AC problems
So this morning I went over to my friend's house who is a mechanic to see about getting my AC recharged. It didn't really need any, so we left it and I drove home. As soon as I pulled out of his driveway, the voltmeter pegged at 18 and the charge/brake light came on. Then the AC turned off. I turned it back on a few times, but now it doesn't come on at all. The voltmeter still reads 18 as soon as you rev it anywhere above 2000 rpm. Needless to say I have no clue what's going on. We didn't do anything other than hook the gauges up to the compressor. That's all we touched.
Any help would be appreciated!
93ToyKid is offline
Sponsored Links
To remove this ad, register today!
Old 05-18-2008, 10:33 AM   #2 (permalink)
93ToyKid's Avatar
BTW this is an 87 4Runner 22RE
93ToyKid is offline
Old 05-18-2008, 10:34 AM   #3 (permalink)
93ToyKid's Avatar
Double BTW the voltage regulator is integrated into the alternator. Tried banging on the alt. a bit but to no avail.
93ToyKid is offline
Old 05-18-2008, 10:36 AM   #4 (permalink)
abecedarian's Avatar
Location: In the air, on the ground- hopefully makin your cellphone work better.
1) check the voltage with a meter at the alternator terminal and the battery, to verify the gauge reading
2) don't operate it with the voltage that high any more than necessary- the battery will act as a sink to absorb and filter some of that extra juice, but it will burn off the electrolyte and when it does, the rest of the system will fry
3) check the battery for proper electrolye levels- not just that the cells are full, but get a hydrometer and check the specific gravity of the cells
4) check for loose of missing grounds from the engine to the chassis and from the battery to the frame
5) check the wiring around the AC compressor to make sure that something isn't touching ground, other than the compressor clutch ground lead.
__________________
Knowledge is that thing people don't have that they hope others do so they can get out of trouble without having to learn anything themselves...
It's time to re-claim 'green' as the color we deserve. Vote me as President, write-in candidate 2008.
Quote:
Originally Posted by stormin94 View Post
You've got my vote for president
While you're at it, write-out EVERY Senator and Representative you can.
join Yotatech chat at http://www.yotatech.com/misc.php?do=flashchat
abecedarian is online now
Old 05-18-2008, 10:38 AM   #5 (permalink)
93ToyKid's Avatar
Thanks for the input. Its an Optima battery. The grounds were the first thing we checked. Also we tried to disconnect the alternator and just run off the battery going home, and the socket came in contact with an exhaust stud and sparked. Is that terminal supposed to be hot with the engine off?
93ToyKid is offline
Old 05-18-2008, 10:42 AM   #6 (permalink)
that alternator wire is in direct contact with the positive terminal of the battery- that's how the alternator output gets to the battery... so yes, it's supposed to be hot
and since you can't check the electrolyte in an optima battery, skip that step.
__________________
Old 05-18-2008, 10:43 AM   #7 (permalink)
check the maxi-fuses in the fuse box behind the battery too.
__________________
Old 05-18-2008, 02:33 PM   #8 (permalink)
93ToyKid's Avatar
ok thanks. well our best bet is that the alternator went bad at that exact moment. i'm gonna take it off and have it tested, then have to deal with finding what it screwed up on the A/C. checked all fuses and everything is ok. Anyone know where the fuse/fusible link to the compressor is?
93ToyKid is offline
Old 05-19-2008, 06:11 AM   #9 (permalink)
93ToyKid's Avatar
bttt. i know someone here knows which fuse is the one for the compressor. my runner doesn't have the fancy little diagram on the fusebox anymore...
93ToyKid is offline
Old 05-19-2008, 06:30 AM   #10 (permalink)
There is a third fuse box in the dash behind the glovebox. It has a black plastic cover. It contains two fuses, the top one is the A/C fuse and should be a 10 amp.
plasticboater is offline
Old 05-19-2008, 09:13 AM   #11 (permalink)
93ToyKid's Avatar
i found it. sure enough the 10amp was blown. apparently the alternator went out at THE VERY INSTANT we were screwing with the AC, and also decided to blow the AC fuse, thereby making it seem like we screwed with something.
new alternator, new fuse, and about an hour of cussing toyota's placement of the lower radiator hose and everything is back in order! thanks guys!
93ToyKid is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
HELP 93 yota 4x4 BATT LIGHT AND BRAKE LIGHT ON not charging maineauto General Electrical & Lighting Related Topics 1 02-12-2008 10:04 PM
charging problems!!! fatmatt473 Pre 84 Trucks 4 06-17-2007 07:46 AM
Lights on HELP.. trans light, charging light, and brake light krash2k77 General Electrical & Lighting Related Topics 3 04-16-2007 05:20 AM
Please Help: Charging Problems Faded 86-95 Trucks & 4Runners 6 12-07-2005 11:26 AM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
