Cast Aluminum Valve Covers
Old 05-03-2006, 09:41 AM
jammer6's Avatar
I have a 95 4Runner that is going into the shop for rebuild this week and I have found out that the Plastic Valve Covers warp over time and they are $100 each for OEM replacements. I wanted to check with you all to see if anyone knows where I can get some cast aluminum replacement, which should also help with the heat coming off the heads.
Thanks for any help
Old 05-03-2006, 10:02 AM
snap-on's Avatar
they warp? they have like 14 bolts holding them to the heads. 1) it is unlikely they warp so much that you cant tweek them back in place when you tighten the bolts down (to a whole 5lbs or something tiny like that) and the gasket doesnt take up any diffrence.
The largest distance between 2 bolts is like 3" or less. i would not expect you to have leakage any problems with them if installed correctly with new gaskets.
Old 05-03-2006, 10:09 AM
Snorkeldepth's Avatar
On the Jasper website they say this about the 3VZE:
"If the orginal engine experienced excessive oil consumption the valve
covers must be replaced. The design of the valve covers used in this
application make it impossible to clean them properly."
I'm not exactly sure what that means.
Old 05-03-2006, 10:12 AM
snap-on's Avatar
jasper is expetionally paranoid with forigien material that was left over from a blown engine contaminating the new block.
thus not being able to "clean them properly" means they want you to replace them incase there MIGHT be any tinny specs of crap that got lodged in them somehow, that you cant get out with "regular cleaning"
same reason they want you to replace a perfectly good oil cooler for like $500.
Old 05-03-2006, 11:08 AM
Thanks for the explanation on that Snap. That had baffled me for a while!
I own one of those brand new golden oil coolers.
calderp
Engine Swaps
08-16-2016 05:15 PM
09-04-2015 09:27 AM
Dennisx2
08-04-2015 01:26 PM
irritech
07-27-2015 05:15 PM
calderp
07-27-2015 09:58 AM
Quick Reply: Cast Aluminum Valve Covers
