Cant find ISR mod parts...
Old 11-23-2008, 02:21 PM
Tubbyfatty's Avatar
Originally Posted by abecedarian
They don't always match the question though.
HAHAHA.
So would the schedule 40 fittings be alright with the heat in the engine compartment?
Old 11-23-2008, 02:23 PM
abecedarian's Avatar
Originally Posted by 89needsatranny
thanks i will look into other materials. is it possible to JBweld pvc to aluminum?? or at least use it as a sealant?
Is it possible? Yes.
Would I trust it / Would I use it as a sealant? Only for a permanent repair. Meaning: if you have a problem with the pcv fitting, it is likely not going to come out without breaking.
Old 11-23-2008, 02:30 PM
89needsatranny's Avatar
yeah... once its on i hope it wont have to come off for a while. in only asking because i dont think the aluminum tailpipe will be thick enough to tap threads and hold the fitting securely enough.
Old 11-23-2008, 02:32 PM
Originally Posted by Tubbyfatty
HAHAHA.
Absolutely. The primary difference between schedule 40 and 80 (and 120) is the wall thickness and has little to do with temperature ratings (unless you're dealing with electrical wiring) or pressure rating (unless you're dealing with high-pressure gas or liquids).
Old 11-23-2008, 02:38 PM
  #25
Tubbyfatty's Avatar
Gotcha, thanks again.
Old 11-23-2008, 02:51 PM
  #26
so let me get this straight...(im a little slow) Tap threads into my 3" aluminum pipe and screw in a 90 degree male pvc fitting with a barbed end, use a little bit of sealant and im good to go?
Old 11-23-2008, 03:00 PM
  #27
Tubbyfatty's Avatar
Yea, sounds right. Do you have the link that has the full install write up?
Here it is if you dont.
https://www.yotatech.com/~corey/tech/blu_intake/blu.htm
Old 11-23-2008, 03:08 PM
  #28
RiCh_90-yota's Avatar
Why dont you just make it easy! Go to autozone or pepboys grab yourself spectre brand air intake tube slap it on done.
[IMG][/IMG]
[IMG][/IMG]
Old 11-23-2008, 03:13 PM
  #29
^^^ looks great but how will i know what size will fit? is that just a generic tube? and does it have the 2 right size fittings? you didn't have to mod anything? i hate finding things out after its too late.
Old 11-23-2008, 03:17 PM
  #30
Tubbyfatty's Avatar
How much was that set up by the way? What did it come with?
Old 11-23-2008, 03:21 PM
  #31
Jay351's Avatar
Heres mine:
*picture down*
I simply went down to the local exhaust shop, had them bend me a tube. Went to the hardware store and got two straight barbed (brass) fittings. I forget the size sorry. You can get the barb and the threads in different sizes.
I also got two rubber hose clamps. Baisicly a 3x3" long peice of rubber, with a band of aluminum around it with two hose clamps. I obviously removed the metal.
To install just drill the holes for the fittings, tap, apply sealant to threads and install. These things are not under THAT much force, no need for a nut... if that nut came off and got sucked into your TB....
Old 11-23-2008, 03:27 PM
  #32
Tubbyfatty's Avatar
Yea i just need to find some rubber tube for making the couplers, i looked all over lowes and home depot and i didnt and rubber that big.
Old 11-23-2008, 03:31 PM
  #33
I spent like $47. http://store.summitracing.com/partde...5&autoview=sku made it work.
Old 11-23-2008, 03:35 PM
  #34
broken link
Old 11-23-2008, 03:36 PM
  #35
too late^^ lol sorry
Old 11-23-2008, 03:37 PM
  #36
Tubbyfatty's Avatar
Link didnt work.
Old 11-23-2008, 03:41 PM
  #37
Jay351's Avatar
BTW - Mine cost:
$10 - exhaust tube
$10 - fittings and band clamps.
$0 - 2 coats of hi-temp black pain I had laying around
And I paid too much.... The best thing about this mod as it can look good and be cheap!
Old 11-23-2008, 03:45 PM
  #38
yeah it was the same link as the one above mine...his is the correct one. ive seen that done before and heard good things....i just want to make my own because blu's is so clean and black. i might end up buying the prefitted chrome one because making one is no longer cheap.(good fittings are too expensive) i cant make my mind up if i want to go with the pvc and make my own or put up another $50 and order that off summit.....
Old 11-23-2008, 03:48 PM
  #39
Tubbyfatty's Avatar
Originally Posted by Jay351
BTW - Mine cost:
$10 - exhaust tube
Thats why I wanna build mine, $20 worth of parts and ppl charge $50 for it.
Old 11-23-2008, 03:55 PM
  #40
Tubbyfatty's Avatar
Yea I hear ya, Ill probably go with the pcv fittings if i cant find any other ones. I just need to find some rubber tube for making couplers.
Quick Reply: Cant find ISR mod parts...
