| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Can anyone identify this part (V6)?
#2 (permalink) |
is that the idle up valve???
#3 (permalink) | |
Location: NW Ark on wooded ten acres...Ozarks at large!
Yep.......
__________________
Matthew Context is everything.... Quote:
http://www.yotatech.com/misc.php?do=flashchat |
#5 (permalink) | |
Aaaawwweee!! Give us a w'ittle kiss....
__________________
#6 (permalink) |
Okay, anyone know where it normally plugs into? The hose literally loops around to itself.
#7 (permalink) | |
On my '92 4rnr, it's for the A/C. I'm sure it is for you truck, as well.
You have the idle up valve and the vacuum switching valve. As far as I know, it's not hooked up the A/C at all, but should route somehow to the intake plenum....as far as the vac lines go. I'd go reference my vehicle right quick, but the wifey-pooh just took off in it to town. It'll be several hours before she gets back. Hopefully some other YT bumb around here will help you out. ![]() Come on dudes! It'd take ya five minutes!!
__________________
#8 (permalink) | |
Wait...wait. I looked at the pic and thought about it. What you have circled I'm pretty darn sure is routed correctly. The longest line running from the valve goes to the plenum.
__________________
#9 (permalink) |
Idle Up,.
#10 (permalink) |
I know the vacuum lines are attached correctly, I never pulled them off. What's getting me are the 2 larger hoses (going behind the evap canister) that are puzzling me. The 2 hoses connect to each other with a short piece of vacuum tubing. It was that way when I got the truck. I have a bookmark of someone else's engine swap with plenty of pics, but they don't have one (they don't have A/C).
#11 (permalink) |
Okay, I found the routing of the hoses. According to this diagram, one of those hoses is supposed to go to the air intake, and the other is supposed to go into the plenum. Mine are connected together in a closed loop.
![]() Somebody show me where they are really supposed to go. |
#12 (permalink) | |
If it can wait, my wife will be home in about an hour.
__________________
#13 (permalink) |
oh, it can certainly wait. My truck probably won't be turning over for another month or so lol.
#14 (permalink) |
then some spanky spanky...
__________________
1991 Pickup - STD Cab - 22re - 5spd - 2wd - DD - Cobra CB w/4ft whip - Hella 500ff - 27" swampers - Flowmaster 40 series - Aussie locker |
#15 (permalink) | |
Lol.....hey, hey! That's nunner yer buziness!
__________________
#16 (permalink) |
^ Not if Kirk was filming it
__________________
#17 (permalink) |
HAHAHA.... ok, not here to guys..... But really???? what is the deal with people and vacuum lines??? Why does everyone insist on routing everything all screwed up, i literally, think people just plug in hoses where ever they see fit until it runs something like normal, and there like yeah, ok. ????
#18 (permalink) | |
Quote:
Forget the initial query. I found out I was looking at the wrong set of hoses. But, I do have a pair of hoses that loop, with a vacuum pipe at the one end. Anyone know where this goes? I can take a pic if needed, but they are similar to the ones used on the idle up valve, maybe slightly longer. |
#19 (permalink) | |
vac lines my god just cap them all off you dont need them!!!!!!!! even the fuel lines you dont need them too for that mater the 3.0's run on love so drain that paper weight called a gas tank and send me what ever you find inside of it ill pay shipping lol
no really though vac lines are funny they go from here to ther back over here then splits over to there and before you know it you go one big rubber rollercoster under your hood as for the loop toyota used the same parts for the high end model as for the chepostake model i guess you just dont have what that goes to so id say dont worry about it
__________________
GO TEAM LAZY!! my name is ALLAN yeah its a 22re 5-speed 4wd 1987 4runner with a cam, snorkel, welded rear Quote:
www.myspace.com/whatsadisplayname |
#20 (permalink) |
shood id say that 3.slooo would be good without the coolant lines too
__________________
Screw you guys I'm goin to TTORA Mods, please be mature and leave my sig alone, thanks. No, I will not be your friend. |
#21 (permalink) | ||
He started it, Swansen.
![]() Quote:
<<(and, no comments from the peanut gallery....please)Yeah, get some pics. The 4rnr's home and I can help route whatever you need today.
__________________
#22 (permalink) |
Okay, here are some pics of it. I'm sure when I'm done getting things together it may become evident where it goes. I'd like to know ahead of time though, if possible.
#23 (permalink) | |
looks like my power steering idle up lines just blocked off all cool like lol
__________________
#24 (permalink) | |
Quote:
Can anyone take a pic of that location for me? Edit: I found a pic, and I do have a broken air valve. The plastic ports are knocked right off. Last edited by Cyberman; 06-24-2008 at 12:34 PM. |
#25 (permalink) | |
Hey.....take a pic of your broken valve. And, get a part number. I might have one, if you'd like.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Please help me identify this part | KZN185W | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 11-11-2007 05:45 AM |
| Small leak... identify this part for me | JML | 86-95 Trucks & 4Runners | 7 | 11-06-2006 04:22 PM |
| Identify this part for me... | One More Time | 86-95 Trucks & 4Runners | 7 | 10-31-2006 03:20 PM |
| Please identify this part and tell me if it bent!! | fireteacher | 95.5-2004 Tacomas & 96-2002 4Runners | 40 | 10-03-2006 04:27 AM |
| 3.0 part, can you identify this hose? | weezy | 95.5-2004 Tacomas & 96-2002 4Runners | 13 | 06-20-2005 07:54 PM |
