Can anyone ID this Dana 60 hub seal? I'll send you a six-pack
I'm having a devil of a time figuring out what hub seal I need for my rear Dana 60 axle. I am leaking diff oil out out the rear tube onto my rotors, brakes, and tires. yuck...
I pulled the axle shaft out and I can see the hub seal, but I cannnot figure out the part number to replace it???
If anyone can point me in the right direction, you got some cold ones coming your way...
It's a Dana 60 rear , disc brake conversion, 30 spline shaft....side note: how bad is it to be leaking diff oil onto brake parts? I've heard eventually you will ruin your pads and rotors, but so far I see no ill-effects...
Pull it apart and measure every thing
The ID the OD the thickness of the seal.
Go to your local Seals`rus and have them match to what is close because your measurements may be off
About the only way if the numbers are gone from the seal.
Then you have no real clue just what that axle housing started out in.
Gear oil will make your brake pads grab and depending on your brake use could start on fire.
theBAYsic
09-16-2015 05:21 AM
