Cam sprocket backwards?
Old 08-23-2014, 08:57 AM
grizzy1967's Avatar
Did a timing belt, water pump and idler replacement about a month ago. I did not remove the cam sprockets.
I tore it all back apart to replace the knock sensor and wire, A problem I had since I bought the 1994 4runner 3vze.
Well I noticed that my passenger side cam sprocket has the ridge facing the front of the runner and everyone else's in the internet is facing the block.
If I can figure out how to post a pic I will.
Old 08-23-2014, 09:03 AM
grizzy1967's Avatar
Notice where the vice grip on the passenger side is holding the t belt on notice the ridge
Old 08-23-2014, 09:05 AM
grizzy1967's Avatar
Question being will this effect anything? I guess that's what I need to know
Old 08-23-2014, 05:44 PM
Shoua's Avatar
It's normal.
I noticed that too when I did my timing belt/water pump. But even in the Toyota factory manuals, it's the way it is.
Old 08-23-2014, 05:53 PM
grizzy1967's Avatar
Thanks ! I wonder what's up with it though ?
Old 08-23-2014, 08:23 PM
bone collector's Avatar
the cam sprocket is backwards so that you can slide the belt over the sprocket without having to go over the lip of the sprocket. the lip being backwards also keeps the belt from rubbing the block. it is cheaper to machine one sprocket and used one backwards than to make 2 different sprockets
LittleUgly
15
01-02-2020 01:30 PM
moparbay
10-06-2015 09:24 AM
shredder4286
10-01-2015 01:09 PM
tylermx71
09-29-2015 08:49 PM
whiteyota93
09-29-2015 02:31 PM
Quick Reply: Cam sprocket backwards?
