A/C switch problem.
Old 05-19-2008, 08:36 AM
plasticboater's Avatar
A/C switch problem.
Good morning, I have a 1987 22re 4runner with an A/C problem. The system is charged and at proper pressure and cools well when 12 volts are applied to the compressor plug in the engine compartment. There was no power to the compressor through the dash switch. The 10 amp fuse was good but the resistor on the dash switch was blown. I replacd the switch with a new one from Toyota, the resistor was different (looking) on the new switch. After installing the new switch, the compressor engaged, the idle increased and the system cooled. Once. Then the resistor blew again. Does anyone have an idea as to what is blowing the resistors? Thanks. Mike
Old 05-19-2008, 09:10 AM
93ToyKid's Avatar
is your alternator putting out too much? this happened on my 87 yesterday. just had finished charging the AC and then the alternator went out at THAT EXACT MOMENT, causing the AC fuse to blow. so it conveniently made it seem like we had screwed something up.
Old 05-19-2008, 09:20 AM
I get just over 12 volts at the hot lead that the switch pulgs in to. The 10 amp fuse does not blow, just the resistor. No other electrical problems. Thanks for the reply. Mike
Old 05-21-2008, 05:56 PM
JamesJ's Avatar
Same Prob
Did the dash switch light up even thought the resistor was blown? I am having the somewhat of the same problem with my A/C.
mussy01
12-13-2016 08:20 PM
PETDOC
08-18-2015 05:29 AM
stock87yota
07-31-2015 10:08 AM
bryan34w
07-06-2015 05:53 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: A/C switch problem.
