A/C and starting issues
Old 06-27-2011, 07:30 PM
coreman23's Avatar
I have 2 issues, so I thought I would put them in one post.
#1:
My a/c doesn't work, the light doesn't come on the switch. Tonight, I found one a/c fuse behind the passenger side kick panel. It was blown, so I tried another fuse and tested the a/c. The a/c light came on for half a second and I could hear the fuse blow. Could there be another fuse that is blown before this one that is tripping it?
Any ideas would be appreciated, I'm not very good at electrical. I know there is another fuse box under the hood, but I didn't see anything labeled A/C.
#2:
When I start my car, it sounds like I am starting it while the engine is running. (That grinding noise.) It's not every time, and usually only does it once, then the car starts fine. Could the starter be going bad? Should I replace or get it rebuilt?
I appreciate any help I can get.
Old 06-27-2011, 07:54 PM
toyotacharles's Avatar
with truck off try to turn the compressor by hand. it might be locked up and causing fuse to blow as soon as clutch enguages.
check the starter to make sure the bolts are tight and starter is firmly attached, if it is then probally the ring gear on flywheel could be rounded in an area or two and starter gear clashing against it.
Old 06-27-2011, 08:01 PM
cody o's Avatar
Try checking the wire going to the compressor clutch for a short to ground.
Old 06-27-2011, 08:04 PM
worshipmentor's Avatar
I wouldn't suspect the compressor being locked up to blow a fuse, more likely it would just BURN THE BELT OFF WHEN ENGAGED lol.
Check for shorted wiring. maybe unplug the compressor and try it to see if the compressor is shorted.
Regency
20
01-03-2020 07:43 PM
vasinvictor
01-20-2016 12:39 PM
Yota.Jay
07-02-2015 12:57 PM
slider417
06-22-2015 10:18 AM
deuxdiesel
06-20-2015 02:49 PM
Quick Reply: A/C and starting issues
