Broken wire..HELP
Old 08-11-2008, 12:46 PM
sincal's Avatar
Broken wire..HELP
Ok i dont know for how long this has been broke but I have no clue where its home is. I get no CEL codes or anything. I checked all fuel injectors and connectors that the wire could reach and all look good. It is just a single braided wire. Please someone help me out here. I do have a high idle, but dont know if that even pertains to this.
P.S sorry for the crappy pics all i had was my phone.
Attached Thumbnails Broken wire..HELP-php0h8d5apm.jpg   Broken wire..HELP-phplkshgipm.jpg
Old 08-11-2008, 12:59 PM
just a 22re's Avatar
ok thats a 22re i can see that bud what wire are you talking about you should take a picture of the wire in your hand or something so we cna see it just a lil better but if it has a braided line over a one wire set-up thats the knock wire seeing is you are in cali maybe the motor was replace or so and a non cali motor was installed with a non cali ecu maybe give me a few better pictures and i can help
Old 08-11-2008, 01:00 PM
and what kind of conector is on end of the wire thanks man
Old 08-11-2008, 01:02 PM
sincal's Avatar
there is no connector on the end of the wire it is the only wire hanging down cut. The k/s is not the little guys home due to i already checked. lol.. I will see what i can do about better pics.. I know there pretty crappy.
Old 08-11-2008, 01:04 PM
sincal's Avatar
The wire is dead center of the pic.. has a little z shap in it.. no connector just broken wire.
Old 08-11-2008, 01:23 PM
is there two wires in it?? it kinda like i said kinda looks like a ac clutch wire but man you should move to milwaukee so i can look at it lol
but anyways.... if its not doing to much wrong and she runs/drives fine i wouldnt worry about it to much man
Old 08-11-2008, 01:27 PM
sincal's Avatar
LOL trust me anywhere is better than cali, but its not a ac clutch wire as to i have no ac and the truck never had ac. It is a single wire i would say 10 guage. The only reason i say broke because the braided wire in the insulation looks jagged as to it broke off.
Old 08-11-2008, 01:37 PM
sounds like it had a date with the fan then but yeah i cant tell from them pictures though buddy the only ones i have that come out under the intake like that are these
starter power and switch
oil pressure
i have no n.s
TPS
#1 injector
the two at the front
and thats about it i think and yes i really dont think i have a k/s but if you say i do then let me see what it even looks like and i can go and look lol
Old 08-11-2008, 01:47 PM
sincal's Avatar
lol. the knock sensor is at nine o clock when looking at your oil filter. Has one single 14 guage wire going to it. Plugged right into the block. hope that helps. But i still cant find what the heck this wire goes to.. Damn previous owner..lol
Old 08-11-2008, 01:55 PM
man if you wanna get into a po talk just come look at my mess lol but eah it might be there then but as for this wire i dont know man i really dont check to see if it has power with key off and on then engine running cold then hot that might help out a lil bit maybe the po had a ele fan on it at one time you just never know
Old 08-11-2008, 02:54 PM
76ANTHONY's Avatar
LOOKS like it could be an old a/c compressor wire, but that pic kinda sux
Old 08-11-2008, 03:05 PM
sincal's Avatar
Yes i know the pic sucks i dont have my camera at my house. Thanks for the help though
Old 08-11-2008, 03:23 PM
Jay351's Avatar
Looks like the ac wire to me. Just trace the wire as far as you can...
Old 08-11-2008, 03:28 PM
sincal's Avatar
I traced it as far as i can and it goes into the wire bundle under the intake manifold then into the fire wall, possibly to ecu
Old 08-11-2008, 03:33 PM
76ANTHONY's Avatar
i wasent baggin on ya, i was just saying, to be 100% sure i need a better pic, but im dam sure thats a/c from what i see
Old 08-11-2008, 07:08 PM
iamsuperbleeder's Avatar
does your temp gauge work and you can verify that it's plugged in on top of the intake manifold by the head?
that's really the only other single wire plugin on that side of the motor that I can think of that hasn't been mentioned...
Old 08-11-2008, 07:12 PM
Jay351's Avatar
Remember, these trucks are wired up for all available options from the factory. Sombody might have clipped that wire or something...
Old 08-11-2008, 07:37 PM
toyotatom93's Avatar
Hard to tell if it is factory or not, or what guage. To me it looks aftermarket, so my guess is a power wire for an amp.
Old 08-11-2008, 07:53 PM
Jay351's Avatar
I don't know of many installers who would go through that much trouble to intertwine it with the factory harness...
Old 08-11-2008, 07:54 PM
sincal's Avatar
well i am a electrian / electronics tech by profession so the guage wire is a 10 gauge wire. My temp gauge works as it goes up and down like normal. As to aftermarket i have no idea, but i dont think someone would have taken the time to wire it all the way threw the original wire loom, just a guess. The truck is running fine other than a abnormal valve noise.. now thats frustrating.
Quick Reply: Broken wire..HELP
