brake woes..
Old 01-31-2011, 09:32 AM
cman1's Avatar
brake woes..
alright,im continuing on my 86 p/u,ive replaced front brakes and calipers (rotors are good)all lines front to back,bench blead new master cylinder...blead the system twice with the wife pumping the brakes system (shes a real trooper)from lt rear,rt rear, rt front,lt front.adjusted back pads to where you can barely get the drums on.i cannot get any more air out.pedal still goes to the floor??? you get about 1" of pumping on the firewall end.the petal rod is right against the master cyl when installed.by the way ,this is the second master cyl in two days because i questioned its working because of no pedal after bleeding.now,with the truck running,when i pump the brakes i lose vaccuum.light hissingi checked the check valve from the master to the engine and its good. .if my power booster is bad,that wouldnt cause me to have no pedal,would it? the friggin booster is the only thing i havent changed,yet.... any help would be appreciated.
Old 01-31-2011, 09:52 AM
waskillywabbit's Avatar
Bleed the lspv?
:wabbit2:
Old 01-31-2011, 09:53 AM
stepside trd's Avatar
You didn't mention if you bench blead the master before installing it on the truck.
Old 01-31-2011, 09:58 AM
metallurgy64's Avatar
I ditto WabFab - there is a bleeder on the lsp valve way up on the driver's side frame rail above rear axle to bleed and its usually loaded with air if the system has been opened.
Old 01-31-2011, 10:52 AM
cman1's Avatar
i did bench bleed the master,but i did not know about the lsp valve! would it hold enough air to make the pedal not pump up? also,are you talking about the valve on the passengers side frame rail?
Old 02-07-2011, 11:04 AM
cman1's Avatar
Well,when i cannot find a solution myself ...you guys always come through.i didnt even know that was a bleeder!!!it looks like a grease zerk. that was it, blead it and have driveable brakes!! thanx guys!!!!
Old 02-07-2011, 11:14 AM
Junkers88's Avatar
Score one more for Wabbit! Damn that guy is good, he should open a shop or something.
Glad it works now.
1uzRunner
63
11-10-2018 03:58 PM
old87yota
09-09-2015 12:39 PM
fabing455
09-07-2015 08:08 AM
Scatterbrain
09-03-2015 06:46 PM
Quick Reply: brake woes..
