brake master cylinder float issue?
Old Sep 8, 2008 | 07:15 PM
bigt's Avatar
ok so my new hilux surf.. brake light on the dash comes on.. not low on fluid but when i un-plug the sensor light goes off.. this master looks the same as my 4runner but has a float in the top not the sensor thats on my canadian runers..
does anyone know what truck this is off?? can i clean the float?? just leave it unplugged??
i know this is it cause the light goes off but will go back on when its unplugged but i pull the ebrake.
heres a bad pics its in the upper
Old Sep 8, 2008 | 08:19 PM
iamsuperbleeder's Avatar
try removing the screen in there and see if that helps
my 91 PU did the same thing when I first got it; it drove me nuts. the fluid was at perfect level and the parking-brake was releases, and the light was still on. I thought maybe the float was getting cought on that screen for some reason, so I removed it and havn't had problems since.
just make sure you don't put sand into yer brak fluid resevour later on since you wont have the filter there N E more
so is it hard to find parts for that thing in the states?
Old Sep 8, 2008 | 08:34 PM
project91's Avatar
I wanna be the 1st peron ever to swap that engine into a 91 4x4 pickup!!
Old Sep 9, 2008 | 04:34 AM
bigt's Avatar
ots of people hve swapped it.. www.toyotadieselmadness.com
im in canada..not that hard to find parts..oil filters from toyota and any other parts for the engine i can order from b.c or edmonton... everythng else on the truck is the same as a runner
Sleaker
Aug 26, 2020 06:03 AM
jasonty
41
Dec 23, 2018 01:00 PM
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
