brake lights and bulbs not working
Old 07-09-2005, 05:49 AM
jtm994's Avatar
my break lights on my 95 4 runner are not working ive checked the fuse and really cant figure out whats wrong with them. any idea what could do the trick to get them working again. if not how much do yall think its gonna cost to fix them bad boys?
Old 07-09-2005, 08:55 AM
Yoda's Avatar
Check the bulbs. They go out one at a time, but you don't know til they don't work at all.
Next would be the switch (down by the brake pedal).
Old 07-09-2005, 09:56 AM
2ToyGuy's Avatar
If you have a multimeter, you can check for voltage in the lamp socket directly, and at teh switch. After that, it's a matter of tracing the wires. If it's just the bulbs, I'd strongly reccomend LED's as replacements. They use a LOT less power to operate, and they last about forever. Most are tested out to over 10,000 hours of continuous use. They're more expensive, but since chances are you'll never have to replace them again, they pretty much pay for themselves.
Also, make sure the grounds are good. A dirty socket or broken ground wire can cause the lights to not work also.
Good luck, and keep us informed!
Old 07-10-2005, 05:03 PM
erics truck's Avatar
check switch for sure. try adjusting it around and see if it works at all. I have been dealing with the ame prob for 6 months
Old 07-11-2005, 11:30 AM
jtm994's Avatar
alright tried the swich but they work when i put on the headlights so its not the bulbs they just dont work when i apply the breaks.
Old 07-11-2005, 11:47 AM
jc1kz's Avatar
not the stalk switch, check the switch down by the brake pedal....
if that goes out your brakes work but they won't light up......
Old 07-12-2005, 12:05 PM
2ToyGuy's Avatar
Also, the brake lights are NOT the parking/driving lights. You have 2 different filaments in the same bulb. One energizes for the parking lights, the other when you step on the brake. Just because the bulb lights up when you turn the headlights on means nothing. It's entirely possible to fail the brake filament while the other is perfectly good. Make sure your bulbs are actually good for the brake filament, not just the parking light filament.
Aleeex_u
06-05-2016 06:52 PM
gog1968
06-22-2015 05:55 AM
ItsAtoyotaLIFE
06-21-2015 11:45 AM
LSUMatt1514
06-26-2002 05:03 AM
Leonel
06-13-2002 02:42 PM
Quick Reply: brake lights and bulbs not working
