Bj Spacers And T-bar Crank!!?? Please Look!!
I get pretty darn good IFS-flex with BJ spacers, 26mm T-bars, low profile bump-stops, swaybar disco's, and aftermarket shocks. I call it getting the most out of the suspension I paid for I can post some pics later on.
It's all a moot point whether ball-joint spacers will help you clear bigger tires, because arguing the semantics of "clearing" the tires will take forever and we won't get anywhere. The fact is that if you get bigger tires, you should decide how much rubbage you're comfortable with, and where it's rubbing, so that you can decide whether your tires will be ok or not. You might decide you want big bump stops, I decided instead to hammer my pinch weld flat and dremel my fender a little bit, but now all I rub on is the swaybar at full lock and a little on the pinch weld full lock/stuff with 33x12.50 TrXuS M/T's (helped by a 1" body lift). Sure, the CV's are possibly in danger in some situations, but being aware of your CV angles and adjusting driving style accordingly is all that is required.
I'm really getting sick of the sweepingly generalized "suspension lifts don't let you clear bigger tires" argument. All it takes is a little know-how on where the trouble spots could be, and you can easily make your IFS perform like you want it to, suspension lifts notwithstanding.
Thanks, backspacing should help fix that as well as shaved control arms.
FYI: I've been trying very hard to figure out a way to get only 1.5-2" of lift out of my T100 and fit 33's and it comes down to adding a leaf pack in the rear and bj spacers. Roger and I were discussing it and the only other thing he said I might need is a 1" body lift. But overall he said I should be able to fit 33x12.5's with maybe minor rubbing if I just use the spacers and rear lift with the correct backspaced wheels.
The runners and tacos will have more problems fitting 33's than the T100 will though.
#26
I have bj spacers, no tbar crank, 33x12.5's on 3.75" backspaced rim, stock bumpstops, no swaybar,no trimming, or pounding of the pinchweld. I get very minor rubbing, although there is no way I could run this with snow chains.
#28
My suspension is stock.
I have a 2" BL.
I run 33X12.5x15 Radial TSL's. I can't remember for sure but my backspacing is either 3.75 or 3.5. I have NO rubbing when wheeling.
The pinch weld is hammered and fender is trimmed because I did run 35X12.5 for awhile on the same rims. Only rubbing there was on the rear mud flap or if I stuffed the front REAL hard when wheeling.
I have a 2" BL.
#29
I think BJ spacers are a great invention, and would be putting them on my truck if I werent selling it.. its just one of my biggest toyota pet peives when i hear people saying they create room for larger tires... they dont... they do allow use of a larger tire that would rub without the lift, but the rubbing issue is still there just not noticed until your on the trail, or hit a speed bump while turning...
#30
actually it does allow a bigger tire, think of the geometry, your lifting the body higher than the axle... therefor giving you more room for tires. it does increase travel , i was thinking backwards.
#31
I want to lift my 88 runner about 2" in the front. I've got 26mm torsion bars and a set of a-arms already cut for BJ spacers. I got this stuff from Seaflea, and he told me with the set up to take the swaybar off, he's gone sas now. This was mentioned in a post above, what is meant by swaybar disco's?
#32
#33
ok Question. I am not tryin to high jack a thread but im thinking about adding BJ spacers to my truck. Its already lifted 4inches but heres why.I want to relax the t-bar and add the spacer to kee the same ride height but free up some movement. I dont want to lower the truck any but the suspension on it is too stiff front and rear.I was planning on adding a different rear spring pack to keep it up or maybe just remove the overloads.
#34
Ok, I have an 89 4runner (see my trucks profile in my sig) I have BJ spacers, 1.5" torsion bar crank and a 1" body lift. I run (bigger than most 33's)33x15.5x15 on 15x8 inch wheels, not sure but i believe the back spacing is 3.5" to 4". my fenders are very lightly trimmed. the only place I rub is in a full lock turn to the left and its on my sway bar and under acceleration (tire deflection) It rides as smooth as mud tires can and gets about as decent flex as a near stocker can. I did not change my bump stops as it would only gain me a small amount and the stockers are plenty soft and will compress.
Today I have over 20k miles on this setup, and it works very well.
feel free to email me about any more Q's
Mike
Mike
#36
Sponsoring Vendor
Ok I may as well join in. This has been discussed many times before and the only thing I will add from my perspective is I have run them on both my '91 and my '92 and only had to pound the pinch welds on the '91. I run 33x12.50's and the only rubbing I get on the entire vehicle is the insde of the fender flare on the rear axle. For those that have wheeled with me, you know that I run mine hard and yes I have broke both the inner axle and a couple of CV's. Just a note on that ....All three times I was in a turn with the front ARB locker engaged. Took three times to convince me that you shouldn't do that. Anyway.....as long as you are going to stay IFS this is still one of the best setups. If you want more than that you need to SAS it.
#37
i have been reading all of what everyone has been saying, and i am about to buy some bjs my self and what i get from this convo is yes u can fit bigger tires but u cant flex them into the fenderwells with out rubbing so yes if u want bitter tires for looks they yea go ahead but if u wheel it alot then u will rub because it still stuffs the tires in the fenderwell the same as stock am i right?
#38
Sponsoring Vendor
#39
Would work quite well...
