BJ spacer pics anymore like this and how much did you guys have to cut out?
Old Nov 16, 2007 | 09:32 AM
4x4YOTA's Avatar
does anybody have any pics of there BJ spacer installed and tell me how much they had to cut off the get it to fit... thanks
Old Nov 16, 2007 | 10:22 AM
Belize Off Road Team's Avatar
suscribed, im about to buy some spacers, i wasnt aware that you had to mod to fit!
Old Nov 16, 2007 | 10:49 AM
AxleIke's Avatar
That pic looks about like mine.
Looks like you got it done right.
Old Nov 16, 2007 | 10:53 AM
so you have to cut the top A-Arm to fit the Spacers!!!!?
Old Nov 16, 2007 | 10:56 AM
AxleIke's Avatar
Uh...yeah. Its pretty clearly stated on their website that you have to do that.
http://www.sdori.com/SDORI_4WD_Spacer_Install.html
Old Nov 16, 2007 | 11:11 AM
ok well, i would have thought that i had previously stated that i am getting a Old Man Emu 2" lift w/ spacers & coils from TRDparts4u.com i normally dont get instructions till i get the product. thanks for the additude
Old Nov 16, 2007 | 11:51 AM
AxleIke's Avatar
Your welcome.
Though, I'm puzzled, since I gave no attitude, but answered your question.
To clarify, nowhere in this thread did you say you were looking at the kit from TRDParts4U. BJ spacers come from SDORI, and some vendors sell his stuff. You seemed indignant that you'd have to cut the A-arm. While I agree that instructions usually come with a product, it is often a good idea to research what is involved before you buy.
In the end, there really isn't any harm done, is there? You now know what you are getting yourself into.
Good luck
Old Nov 16, 2007 | 12:03 PM
Originally Posted by AxleIke
Your welcome.
Good luck
i thought they went on the bottom, goes to show what i know, im not a mech, i know how to change oil, shocks, and a few other small things, i dont know anything else, oh and grease nipple locations. for the longest time i didnt even know what BJ ment on BJ spacers, Ball joint who knew. and the TRD parts package lift that i am buying, the spacers are NOT from the SODRI they are in fact from OME. i do realize that you probably know a world more in mech stuff on toyotas, i know facts and first hand tests, not installing lifts, and things like that, this is my very first vehicle, i have owned for 2 years now and i know it, inch for inch, what i dont know, aftermarket things ANYTHING aftermarket and lift kits are very new to me, im just discovering lifts and only want to find out myself. good to know people can help me when i need to know everything about aftermarket stuff
Old Nov 16, 2007 | 01:40 PM
treknwil's Avatar
Thank You! Actually its mine. Here's another pic without the spacer installed, so you can see the cuts I made to clear the spacer.
Old Nov 16, 2007 | 02:11 PM
AxleIke's Avatar
Happy to help. Also, just FYI,
OME doesn't make Ball Joint spacers.
I'm assuming you are purchasing one of the kits in this post:
https://www.yotatech.com/forums/f37/...s4u-com-54794/
As you can see, all the BJ spacers are from SDORI.
Old Nov 16, 2007 | 02:59 PM
4x4YOTA's Avatar
so about how far back did you trim... I just cut the lip off but not sure if thats enough?
Old Nov 16, 2007 | 04:46 PM
elripster's Avatar
I can help here.
We sell primarily to vendors. I sell very few pairs of spacers directly and that's just fine. We make the spacers and others bundle them with other parts one needs in a lift. This is good for the customer and lets each business focus on their area of specialty. It's a good arrangement.
The trimming is very easy. A 4.5" cut off wheel on a $20 angle cutter will go through that inner lip in a minute or so. Grinding with a die grinder will take a LOT longer but will work too. You are only trimming about 3/8" or about 9mm of the lip on the inner underside of the a-arm.
If you have any questions feel free to post up and I'll subscribe to this thread.
Frank
Old Nov 16, 2007 | 05:31 PM
4x4YOTA's Avatar
thanks I apreciate it alot...so Im pretty much only getting rid of the lip edge nothing more
Old Nov 16, 2007 | 06:58 PM
James Dean's Avatar
You only have to trim about 1/4" or so from the inside lip. It doesn't effect a structural part of the control arm. A die grinder makes quick work of it.
Old Nov 16, 2007 | 07:18 PM
4x4YOTA's Avatar
so a 1/4" back from the lip or a 1/4" total ???cuz I cut the lip off so I need to take off more...I never removed the ball joint did it all still together dont want to take any thing apart til its ready to go together
Old Nov 16, 2007 | 07:21 PM
treknwil's Avatar
I installed 1" spacers, so I did need to clear as much as if I would have gone with 1-1/2" spacer(1" spacer fit up inside of arm only the bolts didn't clear.). I only needed to clear the bolts. I used a angle cutter also. They work very well and cut though like butter. I didn't remove any material I just bent it out of the way. Its easier than it looks.
Old Nov 16, 2007 | 07:38 PM
mikes350's Avatar
Also remember that the stock tires/rims may not clear the A arms once you install the spacers make sure you have lots of clearance. Mine rub but i cut the a arm back and rewelded in a new plate so they have alot of clearance now when i run the stock tires and rims , most rims with 3.75 backspacing or less seem to have no clearance problems
Old Nov 16, 2007 | 08:07 PM
BLKNBLU's Avatar
Here ya go. A few more pics.
Pics start at post #17
https://www.yotatech.com/forums/f31/bj-spacer-question-58081/
Old Nov 16, 2007 | 08:27 PM
4x4YOTA's Avatar
Im already running wheels with enough backspacing I have bout 2" between my tire and control arm
Old Nov 17, 2007 | 07:02 AM
elripster's Avatar
I have never tried to cut off that lip with the joint installed, that's a first. I didn't know you could do that. I always just hold the spacer up to the arm, see where I need to cut, and make the incision.
I would just install them. If you have cut that lip you will at most only need to trim a tiny bit more. We're talking adding maybe 5 minutes to the total install.
Frank
