bit of an issue with my brakes..
Old Sep 6, 2008 | 04:39 PM
machine23's Avatar
so whenever im out cruising in my lovely 94 3.slow sr5 runner, and if i happen to go over a bump or hit a pothole while braking, my brakes basically fail for about 3 sec. this can be no bueno when you are driving with your lady. this has been happening for a while. what happens is right after i hit a bump i can feel my pedal rattle a lot, i can hear an odd buzzing noise through the firewall coming from the master cylinder, and my brakes wont work for like 3 seconds.
anybody know whats going on with my precious runner? im too afraid to do any wheeling with the brakes doing that after every bump
Old Sep 6, 2008 | 05:06 PM
abecedarian's Avatar
do you have the anti-lock brake system? if so, you will have to take it to have the system checked, unless you are a mechanic with all the fittings and pressure gauges that are required.
if not, there is no rational excuse for a 3 second delay in getting your brakes to operate unless there is a significant amount of air in the lines and they all need bled.
Old Oct 1, 2008 | 10:23 PM
Sin91's Avatar
Hey Abe, my brakes are acting wierd too lately...hmmmm
Old Oct 2, 2008 | 03:38 AM
jsn_stockard's Avatar
What vehicle?
Old Oct 2, 2008 | 05:17 AM
jason191918's Avatar
Did you check the fluid level in the MC? If you are low, the bump will let air in the line and then it will bleed itself out 3 seconds later.
Old Oct 2, 2008 | 06:56 AM
jd20phill's Avatar
mine does the exact same thing. 94 4runner 4x4. A solution to this would be great.
Old Oct 2, 2008 | 08:22 AM
nv4runner's Avatar
The buzzing is probably the rear anti-lock brakes. Does it happen with hard braking only or even with light braking? If I'm hauling down a dirt road or even a paved road and slam on the brakes the rear ABS will kick in if I go over a bump. Gradually slowing down I've never had that problem. It could be that your shocks are shot in the rear so you are getting a lot of bounce out of the back and a tire or both rear tires are loosing good contact with the ground. Is the CEL or ABS light on?
bigjstang
Jun 2, 2025 03:56 PM
Sleaker
Aug 26, 2020 06:03 AM
raptor510
Feb 17, 2017 07:11 AM
lfcarrion3
Jul 18, 2015 04:05 PM
Coreyr384
Jul 10, 2015 11:13 AM
