bed removal help
Old 03-31-2011, 06:04 PM
dmaxxx21's Avatar
bed removal help
I recently bought a 90 4x4 truck and it has a 3 inch body lift and i'm wanting to remove it and i cannot get the bed off, the bolts turn and the nut turns also (the nut is on top and bolt head on bottom) and there is no way to put a wrench on it to hold it. so what should i do, cut them or just leave it like it is or what, it has 33x12.50 on it now and i'm going to 31x10.50 and i think it won't look too good with the lift on.
Old 04-01-2011, 07:28 AM
HawkStrong16's Avatar
If you don't care then just go ahead and cut them, you can buy new bolts at a hardware store. Get grade 8 bolts.
And you're right, 31s with a 3in lift wont look good.
You're gonna be better off without the body lift, if you want a lift later down the road get a suspension lift.
Old 04-01-2011, 07:36 AM
waskillywabbit's Avatar
Cut the bolt heads off, remove filler neck stuff, tail lights, and pick the bed off.
:wabbit2:
Old 04-01-2011, 08:21 AM
Magnusian's Avatar
Location: Downtown Heckronto, Ontario, Soviet Canuckistan
:wabbit2:
Don't forget to conscript some friends, be a little hard to get the bed off by yourself.
Old 04-01-2011, 08:27 AM
jessed59's Avatar
get a buddy to help then u could sell the body lift for a few bucks also
Old 04-01-2011, 09:23 AM
dmaxxx21's Avatar
Thanks, I think it will be alot easier to just cut the body lift pegs cause they are easier to get to and I hope the cab will Not be this hard, also can I get cab bolts from hardware store.
Griff
93-98 T100s (Build-Up Section)
09-23-2015 10:11 PM
58rennur4
08-04-2015 08:49 AM
DrZero
18
07-24-2015 11:31 PM
Backcountry411
07-24-2015 08:06 AM
mickyd9990
07-06-2015 09:01 AM
Quick Reply: bed removal help
