Beck Arnley tie rod ends
Old 01-15-2009, 12:17 AM
Matt16's Avatar
I know OEM is usually best. I want to know your (ie: not what you've heard) experience with Beck Arnley.
I found some Beck Arnley tie rod ends (outers) for $15 locally. Anyone have any experience with Beck Arnley, any horror stories that should make me return them. I was going to do Moog, but the price was more than I could justify at the moment with school fees and books having not too long ago drained my account.
They're supposed to be OEM quality, any bad experiences?
Old 01-15-2009, 12:23 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
I've never used B/A mechanical parts, but to save a buck I have used a few electronic parts with no issues. So, if that's any sort of testament.
If you got a good warranty, I'd say used them and not worry about it.
Old 01-15-2009, 12:47 AM
ovrrdrive's Avatar
The BA TRE's from Autozone have a lifetime warranty. I have a blown boot on one of mine and I bought one of the BA's about a month ago but I haven't gotten around to installing it yet. I like that it had a zerk on it so that this time it won't be overfilled with grease and blow the boot again. If it does break though at least I won't have to pay for it again...
Old 01-15-2009, 12:55 AM
Matt16's Avatar
That brings me to an important question. How much grease should go in? One half pump of a gun? Aren't the boots replaceable?
Old 01-15-2009, 01:15 AM
thook's Avatar
Just enough grease to somewhat "bulge" the boot. Really doesn't need much.
Don't know about B/A's, but the Moogs I got as replacement for the original OEM's have a small seep hole that helps prevent the pressure from building up too high and blowing a boot. And, besides, with the Moogs anyway, if you over grease them, the extra winds up just spooging out of the seals. They're not sealed with a wound, metal band like OEM's.
Old 01-15-2009, 01:16 AM
thook's Avatar
Oh, on OEM's, the boots are replaceable. But, if the tie rod is shot, there's no point.....of course.
Old 01-15-2009, 07:33 AM
Matt16's Avatar
For certain this rod ends need replacing. They have around 1/8" of play.
Old 01-15-2009, 08:09 AM
mrmatson's Avatar
Not sure about B/A in particular but I blew out a tie rod end and replaced it with whatever the cheap brand it from autozone and it hasn't given be any problems.
Old 01-15-2009, 11:28 AM
lovetharunner's Avatar
I just replaced all 4 tie rods lastnight. I have no experience with b/a. I picked mine up from JC Whitney. They look like they are good quality and they were in-expensive. I put about 2 pumps of grease in mine as it didn't appear to have any grease from the manufacturer.
Old 01-15-2009, 11:47 AM
Matt16's Avatar
Don't have JC Whitney in Canada. We have NAPA, but that's about the only auto parts chain store that made it up here as far as I know. The three brands we have up here for rod ends is B/A, Moog and "brand X" (cheap, low quality).
Old 01-15-2009, 01:42 PM
We don't have JC Whitney local either. I bought mine online. Shipping is free for any order over $75. Not sure if that applies to Canada though.
Old 01-15-2009, 02:49 PM
Matt16's Avatar
It never does apply sadly. I'm going to give those B/A a try.
Old 01-15-2009, 04:30 PM
myyota's Avatar
I have used Beck Arnley parts on my 4Runner, i have found there parts to be good quality, and i would recomend them.
Old 01-15-2009, 05:58 PM
Jay351's Avatar
Go for it. I like to stick with Moog or OEM, but im sure it will be fine...
Old 01-15-2009, 06:03 PM
86tuning's Avatar
Some Beck-Arnley tie rod ends are actually circle-555 brand, which is OEM.
If the box says "Made in Japan" then it's OEM.
If it's made elsewhere, it's not a real big deal, B-A parts are good quality.
Old 01-15-2009, 06:13 PM
Jay351's Avatar
I remember hearing about that (circle-555 brand). I have never seen one before...
Old 01-15-2009, 06:21 PM
Matt16's Avatar
Yeah, I had a look, you're right, they say Three Five on them.
Now, If I could only get the old one's out. I don't have a puller bug enough to fit over the knuckle.
Old 01-15-2009, 06:43 PM
Jay351's Avatar
I got a puller from princess auto for like $35. Its makes TRE's so easy
Old 01-15-2009, 06:47 PM
iamsuperbleeder's Avatar
or a BFH
Old 01-15-2009, 07:47 PM
Matt16's Avatar
Originally Posted by iamsuperbleeder
or a BFH
I tried that. I just came inside to get the maul which is basically an axe with a 12lbs head. Like most axes the back of the head is hammer-like. See if that and the pickle fork knocks it out. I have very little faith in pickle forks.
I honestly don't think anyone has done any part replacements in the last 10yrs at least.
Quick Reply: Beck Arnley tie rod ends
