Balljoint spacer and wheel spacing
Old 06-18-2007, 05:03 PM
mojo4x420's Avatar
I'm running some chevy 16" rims and I currently need a 1/4" wheel spacer in the front to clear steering and barely clear as it is.
If I install the bj spacers, sounds like I am definately going to need a wider wheel spacer. Does that sound right?
thanks,
Old 06-18-2007, 08:30 PM
Jay351's Avatar
Yes you do. You should get a 3/4" -1" spacer and that should be okay.
I will let somone else chime in...
Old 07-20-2007, 01:11 PM
mojo4x420's Avatar
I definitely needed a wheel spacer. Looks like 1" spacer would have done it, but I had a 1.5" spacer already.
Strangely enough, The instructions say to place some metal under the upper a-arm to keep it lifted a bit. I could not get everything back together like that. I removed the stuff I jammed in there and I easily got my balljoint into the spacer.
terminator
07-27-2015 07:13 PM
KyleT
07-21-2015 07:54 PM
DrZero
07-13-2015 09:59 AM
Yotoder865
07-09-2015 07:51 PM
Quick Reply: Balljoint spacer and wheel spacing
