Bad fuel injector... 3 months old...
Old 04-03-2007, 12:25 PM
Tigerstripe40's Avatar
About 4 months ago, my 4Runner was getting bad gas mileage, and had no power (the 3.0 was rebuilt less than 6 months ago by a reputable shop using ALL new OEM parts).
Anyhow, it turned out to be a bad fuel injector on the number 3 cylinder.
Well, I was driving to work today and I had the same problem as I did 4 months ago... No power...
I pulled the spark plugs (and there is PLENTY of spark) one by one. Sure enough, cyl 3 is not firing...
One more thing.
The thing that initiated the rebuild is that the number 3 cylinder had a rod knock...
So, I wonder if these things are related.
I am thinking that the problem here is the engine wire...
Any ideas here?
Old 04-03-2007, 01:20 PM
dcg9381's Avatar
Check compression on #3 before assuming it's an injector.
Old 04-03-2007, 01:24 PM
rdharper's Avatar
One more thing.
Any ideas here?
When you say 3 is not firing, what do you mean? No spark? Or what?
Old 04-03-2007, 01:30 PM
Compression is where it needs to be.
Also, I am getting spark.
I shocked myself pretty good when I pulled the plug wires to find out which cylinder isn't firing.
It's the number 3 cylinder not getting fuel.
Old 04-03-2007, 03:29 PM
dcg9381's Avatar
good pulse to the injector?
Old 04-03-2007, 04:12 PM
TNRabbit's Avatar
check the pulse to the injector for possible wiring harness short. If that's good, you have a bad injector.
Old 04-03-2007, 09:42 PM
I am pretty sure it's a short or an open in the wiring harness.
I hit a good bump and the engine looses power.
I hit another good bump and everything is working fine again.
icentropy
09-16-2020 02:47 PM
jasonty
41
12-23-2018 01:00 PM
smiley52
07-11-2015 05:16 AM
Poncho0206
07-10-2015 06:21 PM
Kluch8651
07-09-2015 10:39 AM
Quick Reply: Bad fuel injector... 3 months old...
