Axle chunk question!
Old 10-15-2013, 08:28 AM
YotaCurly's Avatar
I have a buddy that has 5.29 gear ratio chunk in a 6 lug solid front axle, would this chunk also work in my v6 6 lug rearend I believe his is a 87 axle??! Any help on this one guys !?
Old 10-15-2013, 08:36 AM
coryc85's Avatar
I think the short answer is yes it will fit. Being that his is in the front of an SFA truck, we know it must be an 8" ring gear, so it will go right into your 8" rear axle. The one question I would have is whether it is a V6 version of the diff or a 4cyl version. Most would say the v6 version is stronger. You can identify the diff type by the housing. Up to you if that strength difference really matters to you, and one more thing, just my .02 here, but 5.29 seems like a steep ratio for 3.0 and 33" tires.
Old 10-15-2013, 08:47 AM
YotaCurly's Avatar
I appreciate the info I thought all v6 diff came with 6 lugs and the 5 lugs came with the 4 cylinders ?? And it's a automatic btw that's why I'm going that steep
Old 10-15-2013, 09:58 AM
93Xtra-Cab's Avatar
It's not 6 cylinder vs/ 4 cylinder that determines whether its a 6 lug or 5 lug. It's 2wd vs. 4wd. 4wd are 6 lug, 2wd are 5 lug.
Old 10-15-2013, 10:20 AM
YotaCurly's Avatar
But would a 4 cylinder diff work in a 6 cylinder diff??
Old 10-15-2013, 10:52 AM
vasinvictor's Avatar
Absolutely.
Old 10-15-2013, 01:31 PM
YotaCurly's Avatar
Anyone have any luck running 5.29's with 33's on a v6 with an auto
oldirtydirt
02-23-2020 09:30 AM
polo451
13
11-20-2016 07:49 PM
delmert
09-30-2015 04:34 PM
88sasturbotoy
08-11-2015 01:56 AM
Backcountry411
07-24-2015 08:06 AM
Quick Reply: Axle chunk question!
