Auto to manual swap question
Old 12-03-2008, 07:02 PM
91Toyota's Avatar
Basically all I need to know is if it matters if the transfer case is mated to an auto or manual.
If I swap to a manual will I need to modify my x-member and get a new transfer case?
I'm doubting the transfer case...but I probably will have to modify the cross member.
Thanks, Trevor
86 4x4 22re
Old 12-03-2008, 07:08 PM
881stGenRunner's Avatar
just but a complete transmission and transfercase unit already together from the junkyard or some one local.
The transfercases ARE different.
Use the X-member from the manual transmission, whenever you buy the tranny just grab that and you will need to use it.
Old 12-03-2008, 07:21 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Or SEARCH, '91......geez...youngsters these days.....
Old 12-03-2008, 10:14 PM
91Toyota's Avatar
Me flipping off a4runner freak
Old 12-04-2008, 12:10 AM
Justinvd's Avatar
You will need a transmission/T-case combo. The tcase in your automatic wont mate to 5spd tranny. Plus the shifter on you auto tcase is like a lever type when the shifter on the 5spd case is just another shifter out the top of the case. And the Tcase for your auto is chain driven and the 5spd case is gear driven wich would make a difference. Not sure about the Xmember though, probably need the one from the 5spd donor. Best bet is to get a complete donor truck and just swap it straight across since you need the ecu and all that stuff anyways and it would get confusing if you just take it out and have it in a big pile.
Old 12-04-2008, 02:36 AM
Ezrider_92356's Avatar
don't forget you will also need the drive shafts the pedal box ass. clutch master and lines on top of all the stuff mentioned above, your best bet is to buy a complete donor truck
Old 12-04-2008, 09:17 AM
91Toyota's Avatar
So you think I need a whole donor truck?
Old 12-04-2008, 09:25 AM
stagger_lee's Avatar
Just sell your auto and and buy a 5 speed. Waste of time IMO trying to swap. How much $$ is your time worth? I know I am worth about $45 an hour. Do the math.
Old 12-04-2008, 09:44 AM
Shawn6string's Avatar
To swap from a auto to manual, you need the ecm or ect ? I have an 88 (3. don't know yet) that has a bad auto tranny and a 92 complete doner t100 with an r150f. I did not know I needed to swap computers..... Do I ?
Old 12-04-2008, 09:45 AM
:hmmmmmm
Old 12-04-2008, 10:16 AM
You need the ECU, the brain, from the manual vehicle. Or figure out how to trick your current ECU into thinking your car is in neutral or park all the time.
Old 12-04-2008, 11:23 AM
please disregard stagger lee. It is every bit worth swapping in a different transmission. i gathered all the parts i need for about $700 and took my dad, brother, and me one saturday to complete. It has been every bit worth it.
I was getting 15mpg with the auto and it was slow as hell with 33s and 5.29s.
Now I am getting 21mpg with the manaul and 33s and 5.29s.
it is very easy to trick the ecm. Splice the 2 big wires in the large white plug on the passenger side of the tranny together and the truck will think it is in N.
Please do your research
Old 12-04-2008, 12:34 PM
Not everyone is as mechanical as you or I, or good at finding parts for that matter. I'm a junkyard cowboy. But I must admit, I was unaware it was that easy to fool the ECU. Thanks! Takes a bit of trouble out of the swap, eh?
Old 12-04-2008, 01:14 PM
annoyingrob's Avatar
Yeah, you just need to bypass the neutral start switch, much like you would bypass the clutch safety switch.
Other than that, the ECUs are very similar. The A/T just has a few extra signals for the transmission computer.
Old 12-04-2008, 01:25 PM
91Toyota's Avatar
Thanks guys! I'm buying the truck tonight and I'll definitely swap out those components. Working on my own stuff is priceless...there is no imaginary charge. I love doing this kind of work...and it makes me happy. lol
Old 12-04-2008, 01:40 PM
more time wrenching = less time wheeling lol
Old 12-04-2008, 01:43 PM
91Toyota's Avatar
True...but do you think I'll be wheeling or wrenching in the long run with an auto???
Old 12-04-2008, 02:21 PM
Their not that bad. Its more power/gearing issue, and mileage loss. Sure will be getting farther then with 2wd though!
My 3slow auto always felt like it was looking for the right gear. Sucked.
Old 12-04-2008, 02:22 PM
91Toyota's Avatar
true...but the auto doesn't work now...so why waste money on another auto?
Old 12-04-2008, 02:25 PM
Roger that! Go for it dude. It all makes sense now. You can do anything, its just a matter of how long it takes. Im OCD, so everything takes me forever because I start cleaning everything and get sidetracked and forget about the job at hand. Besides with yota tech you can accomplish anything.
Quick Reply: Auto to manual swap question
