| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||||
Aussie Locker install question
__________________
1990 Toyota 4Runner 22RE 5spd *Aussie Locker*York OBA* Quote:
Quote:
More info on 4Runners |
#2 (permalink) |
with the bearing caps removed you should be able to slide them into the threads in pretty much the same place they came out of. Then put the caps back on. Then give them about a turn until it starts to tighten up (as per the instructions that came with my lock-rights). Btw if you're doing this on a 2 pinion and had to remove your ring gear, stick the ring gear in the oven at 225 until you're ready to put it back on. It will drop right on with no help from a hammer. But yes you should mark the adjuster nuts so you knew the position they came out in. Then put them back in the same.
http://www.4x4wire.com/toyota/tech/lockright_locker/ Last edited by Beaniam; 06-27-2008 at 11:18 AM. |
#3 (permalink) |
Well, I actually disagree with that, but I'm not sure it matters too much.
I put the caps on, line up the threads, and then tighten them down slightly. Then thread the nuts and make sure they are threading properly. I then set the backlash using a dial indicator, because I don't trust that everything will settle down perfectly as it was before. We're talking thousandths of an inch, and just a few off can mean premature gear wear, or damage. Anyway, just my .02
__________________
1987 Mutant 4runner|Slightly Modified|Lacking general build direction -Lifts and Tires look cool at the Mall, Lockers and Gears look cool on the trail. -Internet Nice Guy |
#4 (permalink) |
It's definitely worth the $14 for a dial indicator at Harbor Freight or similar.
__________________
1990 4Runner 3.0/AT/4WD - 285/75/16 TreadWright D-Muds, SDORI Coil Spacer, Aisin Hubs 2005 Mazda 6i 2.3/MT |
#5 (permalink) | ||
I think it took about 4 turns last time to back one of the adjuster nuts out last time. Does that sound right?
__________________
#6 (permalink) | ||
Secondly, how do you tighten this adjuster nut? Doesn't it take quite a bit of force? Do you have to make some kind of tool?
__________________
#7 (permalink) |
Either I'm confused or putting an Aussie in is a lot more complicated that I thought it was. Since I'll be doing this exact same swap in a week or so maybe ya'll can answer something for me.
Why do you have to reset the backlash if all you're doing is pulling the carrier, installing the AL and reinstalling the carrier? You're not replacing gears, nothing to do with the ring and pinion is changing right? So can't you just mark everything and put it back the way it came out? This will be my first Toyota rear end so if my questions are stupid you can let me know.
__________________
RB4R Life Member. 1989 SR5 4runner. Tread Wright 31/10.50/15's. 4.56 thirds, an Aussie in the @$$, Budbuilt plate, Marlin Crawler front, modified MC rear, Supra MAF conversion, ZUK coils in the rear and 4crawler BJ's in the front, LCE header. |
#8 (permalink) |
http://gearinstalls.com/aussielocker.htm
Another Zuk. This is the one I'm going to print out and use.
__________________
#9 (permalink) | |
To properly turn the adjuster you need a face spanner wrench. A lot of people just use a punch and hammer, but a diff is one of those things where it pays to have the proper tool.
Adjustable face spanner Quote:
__________________
1990 4Runner 3.0/AT/4WD - 285/75/16 TreadWright D-Muds, SDORI Coil Spacer, Aisin Hubs 2005 Mazda 6i 2.3/MT Last edited by Crawdad; 06-28-2008 at 04:07 PM. |
#10 (permalink) |
Double post - sorry!
__________________
#11 (permalink) | ||
Can someone comfirm this:
14. With the carrier in place, you will push it as far as it will go towards the side opposite the ring gear (making sure the bearing races are fully on their bearings). This acts to force the ring gear against the pinion, eliminating any backlash. Try it, when done properly you should feel no play between the ring gear and pinion, instead of the amount of backlash you felt before you disassembled the gears. 15. Find the adjuster ring for the ring gear side, and orient it with its mark in its final position (probably straight up). Place the adjuster ring against the bearing race and slide it down into the threads. There should be no space between the adjuster and the bearing race. The adjuster ring (arrow) in place, flush against the bearing race behind it 16. Now get the carrier bearing cap for the ring gear side and orient it properly. It should slide down on the adjuster ring. Use the two bolts to line it up so everything goes together smoothly. Snug up the bolts. The other adjuster in place, marks oriented straight up as they were when we disassembled the diff 17. The other adjuster ring is ready to be installed now. Orient it with its mark in the final position. Start it out flush with the bearing race, and slide it down into the threads. As you do this the meshing of the threads will force the adjuster ring outwards away from bearing race. Get the other carrier bearing cap, orient it properly so its punch marks match the marks you put on the housing, and use the bolts to help position it over the bearing race and adjuster. Slide the cap down, and it should mesh nicely. Snug the cap bolts. Using a brass punch to drive the ring gear adjuster around one full turn 18. Now you will set the bearing preload and backlash. The adjuster ring on the side opposite the ring gear is sitting out away from the bearing race just a bit. You will use a punch to rotate the adjuster ring clockwise, threading it in towards the bearing race. The first half of the turn should go easily, until the adjuster ring starts to contact the bearing race. The last half will require some force to turn the ring, as you are creating the preload and moving the ring gear away from the pinion gear to create the backlash. The adjuster ring should end up with the mark in the same position as when you marked it and took it apart.
__________________
#12 (permalink) | |
Quote:
I mark the position of the wheels before dis-assembly. Then during assembly, turn the wheel on the RING SIDE(the side with the ring bolts heads) in all the way until the ring touches the pinion and BL is 0. At this point, you have likely went about 1/2 turn past your inscribed mark so back it off until it lines up. With one adjuster set the other is a no brainer. Now, at this point, I also add more CBPL to prevent the ring from deflecting under heavy torque loads. This basically adds strength to the gear set and prevents the outside edges of the ring teeth from "falling off". The basic procedure to add some CBPL is straight forward.....turn each wheel 1 notch tighter using the inscribed marks as a reference. Then WACK both bearing caps with a hammer numerous times WHILE the pinion is rotated back and forth. This has the effect of equalizing the bearing tensions and preventing false backlash measurements. Do that for a couple of notches and your done. Oh ya....don't forget to use lotsa anti-seize. I think a cheap dial indicator perhaps from Harbor freight is a wise investment...take a BL reading before tearing the case out and make sure its about the same after this Aussie install. Take more than 1 or 3 or even 5 measurements....take a BL measurement from every other tooth around the ring. That's about 20 numbers and write them down. That's the best method to document BL accurately. ZUK
__________________
www.gearinstalls.com 2001 white Xtra-cab Taco 3.4L auto TRD 88 Runner/V6/auto/31"/5.29gears ZUK was what my friends in 1990 "tagged' me with when I was building a brand new white 1990 Sami for a magazine cover. The name stuck and I haven't been able to shake it off....not even with antibiotics. Last edited by ZUK; 07-01-2008 at 08:25 AM. |
#13 (permalink) | ||
Thanks a tonne Zuk, this was a real help.
__________________
#14 (permalink) | ||
Alright, I measured the backlash on every second tooth on my 4.56 third, it averaged out at 0.011". The FSM says the backlash should be 0.005-0.007". There is virtually no carrier bearing pre-load (CBPL). The gears look fine, no chips or noticeable scarring.
When I put this diff back together, I suppose I set the backlash, then crank both the wheels a couple notches each? Assuming there is no pre-load, how many notches should they each go? I made a wheel adjuster tool that looks just like the one in the picture below. 1/4" x 1.5" bolts are cheap and fit nicely into the adjuster wheels.
__________________
Quote:
More info on 4Runners Last edited by Matt16; 07-02-2008 at 10:11 PM. |
#15 (permalink) | |
Quote:
what are all of those plates you got welded on there for? did you do that for the the proportioning valve mount?
__________________
1994 toyota 4Runner SR5 Limited 4wd, 3.0 V-6, 5-speed, 31/10.50-15 Toyo A/T, All Pro 1.5" coil springs, Bilstein front shocks, doetsch tech mv12's rears, MC heavy duty clutch, 2.25" Cat-back with 50 series Flowmaster 169,xxx miles |
#16 (permalink) | ||
That's a photo from Zuk's page. No idea. I was just showing the tool I made.
__________________
#17 (permalink) |
o gotcha, my bad haha
__________________
#18 (permalink) |
That plate welded to the left side of my fixture is just a convenient place to secure the dial indicator magnetic base to.
You might get up to 6 notches on each side, Matt.....3 or 4 is probably good though. Yes, I set the wheels back to where the inscribed marks were and usually that gets you to the same BL as before.....Once BL is verified then I move things one notch at a time. ZUK
__________________
www.gearinstalls.com 2001 white Xtra-cab Taco 3.4L auto TRD 88 Runner/V6/auto/31"/5.29gears ZUK was what my friends in 1990 "tagged' me with when I was building a brand new white 1990 Sami for a magazine cover. The name stuck and I haven't been able to shake it off....not even with antibiotics. |
#19 (permalink) | ||
Can I tighten the backlash on used gears? I presume that gears have meshed with 0.011 backlash, so if I set the backlash at 0.006, the gears will have to re-mesh with the new backlash. Am I correct? Do I have to break in the gears again for the new BL?
I am planning on using 80W140 dino oil for few hundred miles, then switching to a synthetic of the same weight.
__________________
#20 (permalink) |
If you go to 006 then the gears might whistle some.....I don't think it will develop much heat so no break-in required.
I think you should stay close to the 011....maybe tighten it up to 009 or 010 and call it good. It won't whistle with a slight decrease in the backlash it has been burned in with.
__________________
#21 (permalink) | ||
Alright, I was playing around with the diff and got .008, but I'll back it off a little. The preload was so loose that you could turn the adjuster's by hand after loosening them one notch with a wrench.
I turned the adjuster wheels about halfway on the ring gear side, and about 4 notches on the pinion side.
__________________
Quote:
More info on 4Runners Last edited by Matt16; 07-03-2008 at 10:27 PM. |
#22 (permalink) | ||
Is setting up the backlash and CBPL really this easy?
__________________
#23 (permalink) | ||
After getting the CBPL and backlash set, I thought that before I pulled apart my truck, I'd just count the teeth to make sure it was a 4.56. I got out my pen and counted. 41 ring teeth and 10 pinion teeth... hell of a strange number for a 4.56. Phone calls have been made. Bugger.
__________________
#24 (permalink) | |
Quote:
__________________
#25 (permalink) | |
Quote:
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Aussie Locker - Ease of install? | RiNkY | 86-95 Trucks & 4Runners | 14 | 12-30-2007 05:02 PM |
| Aussie Locker Install | jforte5650 | Offroad Tech | 6 | 12-20-2007 09:15 PM |
| E-Locker to Cable Install & Question | 91ToyTrck | 86-95 Trucks & 4Runners | 7 | 03-18-2007 04:51 PM |
| Aussie locker install | Nathan Buchanan | Offroad Tech | 18 | 11-29-2004 06:52 AM |
| question about locker install. | doink | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 04-01-2004 06:15 PM |
