Ash tray noise off road
Old 04-20-2008, 10:35 AM
Matt16's Avatar
My ashtray bounce open on anything larger than a speedbump and pennies go everywhere. Its pretty annoying and I'm going to fix it. I'm thinking I'd stick on some velcro to keep it closed.
Have you done anything to quiet the ashtray. It isn't exactly a difficult problem, but I'm curious what others have done.
Old 04-20-2008, 10:37 AM
unclejstoy's Avatar
ya i had this problem once 2 I took out all the pennies
Old 04-20-2008, 10:38 AM
dirtoyboy's Avatar
My suggestion is drive slower or dont keep pennies in the ashtray!
Old 04-20-2008, 10:39 AM
Brenjen's Avatar
I just don't keep change in my ashtray; my buddies threw theirs in the one on my old work truck & dimes kept getting in the DC plug & shorting out the fuse; very irritating to have coins in there to me.
Old 04-20-2008, 10:54 AM
ewong's Avatar
I recall that there is a plastic spring clip that "rides" on the ash tray side rails to add friction to keep the tray from fllying open - at least on the 84-88 ones.
Old 04-20-2008, 11:15 AM
unclejstoy's Avatar
See the ash tray was engineered for the atomic weight of ashes and not pennies.
So filling the volume with penny atoms and not ash atoms over comes the friction of the trays capacity.
Old 04-20-2008, 11:51 AM
Dublin's Avatar
I use to put my change in the dash depression on my 1st gen. It ended up going into the defroster vents to the point that no air would come out. After tearing it apart I was 43 bucks richer. Maybe you should do that, it holds more than your ashtray. Down side is limited defrosting capabilities and zero interest on your savings.
Old 04-20-2008, 01:03 PM
Jdizzydub's Avatar
That's exactly right, hence the name ashtray not penny holder...but i have to admit i used to keep change there to. You can insert small felt cut to size inside to prevent noise, and maybe small strips of velcro to keep it shut.
remove the ashtray and instal a cb in there! keep the change in a small zipper pouch and throw it in the center console
Old 04-20-2008, 11:30 PM
stormin94's Avatar
I have mine LOADED with change, just enough space left so it will close, and that thing rattles bad, and I have to keep pushing it in, otherwise it will fall out, and I will be picking up change for months...
My cupholders rattle, and that's annoying. I just pull those out of the dash about 1/2 inch, and it stops, also, my passenger seat squeeks, and I can't figure out where, just that it doesn't do it when there is someone sitting in it.
Old 04-21-2008, 05:23 AM
racinkid13's Avatar
whats an ash tray? oh, that space next to the cigarette lighter. oh, well theres a aftermarket transmission temp and water temp gauge there.
Old 04-21-2008, 09:41 AM
Matt16's Avatar
It doesn't matter whether or not there's change in there, it still bounces out.
Dirtoyboy, I'm not driving slower when the fish are biting.
Old 04-21-2008, 09:48 AM
Belize Off Road Team's Avatar
Matt, i used to do the same as you, i only have a small knife and bottle opener in my ash tray now. i keep all my change in either the money holders or the little pocket in the center console. behind the shifter, you know where i mean?
Old 04-21-2008, 11:02 AM
aviator's Avatar
Sounds like part of the Plastic slide is worn out. The metal/plastic ashtray sub-assembly is attached to the radio surround with two screws.
A short term fix would be to try a strip of electrical tape along one side of the ashtray slide and see if that gives you enough added tension.
A longer term fix would be to purchase a new sub-assembly.
I happen to have a subassembly or two available with and w/out light.
pm me if you're interested.
As for quieting down the contents of the ashtray a member here years ago used a little spray adhesive and a piece of thin felt with excellent results. Of course once you do this it can no longer be used as an ashtray.
Old 04-21-2008, 11:32 AM
dirtoyboy's Avatar
This is known world-wide as the infamous "Ashtray mod"!!!!!
Old 04-21-2008, 12:24 PM
UKMyers's Avatar
I did the Ashtray mod 4 years ago. For a while there was a member selling the pieces of felt already cut out!!
Old 04-21-2008, 07:04 PM
Jay351's Avatar
Get a new/used plastic peice. 2 screws and its out. Mine fits pretty tight, must be since there was wasnt one in there for 10 years..
Old 04-21-2008, 11:21 PM
stormin94's Avatar
Just smash some old McDonalds french fries in there, then put your change in on top of it. It's cheaper....and you can have a snack for later....
Old 04-22-2008, 07:54 AM
just a 22re's Avatar
ph my god thats nasty lol but matt you want an idea try the tape on one side and get duct tape to go over the try that way it wont come out and felt on the inside and there no sound no opening and if it does there a lid!
jashoeuh
11-26-2017 07:01 AM
polo451
13
11-20-2016 07:49 PM
genuinegemini
08-03-2015 04:56 PM
razorman8669
07-12-2015 12:13 PM
Gamble_STi
07-07-2015 07:54 PM
Quick Reply: Ash tray noise off road
