Anybody recognize this spring?
Old 07-22-2010, 12:45 PM
dntsdad's Avatar
I had this in my box of clutch parts when I pulled out the original transmission. It may be not be related and somehow ended up in that box accidentally.
i am now putting the 5 speed back in and I have no idea where it goes. I think that its too large the be a pedal return. I have the spring on the brake pedal.
Vitals on the truck is 92 excab, was 3.0 (now 3.4), manual, 4x4.
Anyone happen to recognize it?
dntsdad is offline
Old 07-22-2010, 02:30 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Hey now!!! That's off my recliner! How'd you....what the.....man, no wonder this thang ain't been workin' right.
If anything, I'd say it looks like it came off of a drum brake assembly, but it's way too long for that. No pedal returns, either. Carbureted throttle return spring, maybe?
thook is offline
Old 07-22-2010, 02:32 PM
xxxtreme22r's Avatar
not a carb return spring. at least not for a yota. looks way too thin to be a brake drum spring.
xxxtreme22r is offline
dntsdad's Avatar
LOL. no carb anywhere. WTF!
Maybe this thing just ended up in the clutch parts box somehow.
dntsdad is offline
Old 07-22-2010, 02:35 PM
you'll know when parts start flying when driving down the highway.
Old 07-22-2010, 02:36 PM
myyota's Avatar
That`s the clutch peddle return spring, it needs to be installed so that the clutch peddle will come back up all the way after you let off the peddle.
myyota is offline
Old 07-22-2010, 02:38 PM
was just gonna edit my thread to say this, but decided not to since I only have a 22r.
Old 07-22-2010, 02:42 PM
myyota's Avatar
It doesn`t matter, 22R or 22RE, your truck has this spring also, if its a manual.
myyota is offline
Old 07-22-2010, 02:44 PM
also different year different body style, but I can go check on mine if it's the same pedal assembly.
Old 07-22-2010, 02:48 PM
myyota's Avatar
It should be the exact same thing.
myyota is offline
Old 07-22-2010, 02:49 PM
thook's Avatar
I only said "carb" because it looks like the one that was on the '70 Chevy truck I used to have. IOW, I knew your Toyota didn't have a carb, but hey.......I've gotten parts mixed up in boxes before and later going,"where'd the hell this come from". That's all.
I didn't think the clutch return spring was that long, although the thought did occur to me. I just wasn't willing to walk out to my vehicle and look. It's too hot....hehehe.
thook is offline
Old 07-22-2010, 02:50 PM
flecker's Avatar
Location: White Mountains, Arizona (Yes it does snow in AZ)
lol- yeah, a 16" clutch pedal return spring! ha ha.
I don't think so.
flecker is offline
Old 07-22-2010, 02:51 PM
I don't see a spring anywhere on my clutch pedal, nor on the trans housing, just the brake pedal which is only like maybe 6 inches long at best.
Old 07-22-2010, 02:59 PM
myyota's Avatar
If you look up under the dash were the pin goes through the clutch master cylinder and through the clutch peddle you will see a groove on one side of the pin, one end of the spring goes around this groove, then if you look at the lower frame of the dash (its hard to see) you will see a small slot cut in the dash frame, the other end of the spring hooks in there. you really need to get your head under the dash to see were the spring goes.
myyota is offline
Old 07-22-2010, 03:10 PM
Reedr125's Avatar
That theres a muffler bearing spring,,,,,,,,,,,
Reedr125 is offline
Old 07-22-2010, 03:27 PM
redhawk427's Avatar
actually im pretty sure its the clutch belt tensioner
redhawk427 is offline
Old 07-22-2010, 03:41 PM
peow130's Avatar
dude the spring is 16" long..
thats over a foot long.
idk about yours, but my dash is barely a foot deep towards the firewall
peow130 is offline
Old 07-22-2010, 04:39 PM
dntsdad's Avatar
Ya i have the coil type spring on my clutch pedal but for this to be a pedal return, i think that you would have to hook it to your belt loop.
SO, other than the coil spring, there is no other pulling spring on the clutch pedal. Can somebody verify please? Maybe a pic?
dntsdad is offline
Old 07-22-2010, 05:19 PM
thook's Avatar
Bahahahaha! Yeaaahhhh......that was funny.
It's cooled off.....evening has passed. I'll go out and look at mine here in a minute.
BRB
thook is offline
Old 07-22-2010, 05:22 PM
thook's Avatar
That's only on later models. His would have a chain......and be an interference style. Clutch goes, all your lights go. It's kinda sad. Lamp oil is so expensive these days.
thook is offline
Quick Reply: Anybody recognize this spring?
