Any ideas on this noise?
http://youtu.be/Xj5n6c5IMRI
I have to motor somewhat apart but haven't seen anything wrong except no2 pulley. Could the pulley cause this noise??thanks
Just a little background on this. I was in a deep mud hole with the front almost straight up when the noise started. The truck ran started , idled and ran fine afterwards. Only drove it about a mile after this started. I changed the oil and there was hardly any shaving in it.
The water pump is tight. Timing belt seems good . No2 (upper) pulley has some wiggle in the bearings. Plugs were black from carbon along with tops of cylinder heads( looking through spark plug hole). Visually the camshaft looks fine.
theking11863
03-19-2016 09:36 PM
