| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
#2 (permalink) |
My first geuss will be clogged catalytic converter. Slightly loping @ idle can be a stretched out timing belt or tensioner spring.
__________________
Sonoran Steel Early IFS Truss Your IFS is SPINELESS without it SonoranSteel.com I'm Cuckoo For YOTA Trucks! |
#3 (permalink) |
maybe a stuck egr valve
#4 (permalink) |
If your idle screw is not making much difference, it's one of two things:
1. A vacuum leak. Run an UNLIT propane torch around all the vacuum hoses; if it idles up a little bit, you have a leak there. If it idles up a lot, you have a REALLY BIG leak there! A vaccum leak can cause the lean/rich swing you've experienced. 2. The throttle body butterfly valve is not closing all the way due to an obstruction, usually carbon/gunk build-up around the butterfly which holds it slightly open at idle. Good Luck & let us know what you find out.
__________________
TNRabbit Stock '94 DLX XtraCab 4x4 5 spd, Newly Rebuilt 3VZE, 17" 2006 Alloy Wheels, 228k miles, AISIN Hub Swap 3.0 Rebuild Thread: http://www.yotatech.com/f116/crap-he...-ghost-108156/ |
#5 (permalink) |
89 3.0 auto 4 runner. Same exact symptoms without trouble codes. I suspect air leak as well as it came instantly and does not affect running above idle. Will keep watching your thread, let you know what I find. Mike
__________________
1995 xcab with blown up 3.0, soon to be 3.9 Cummins.Plans for SAS as well. 1989 4Runner daily driver, 3.0, 3.5 body lift, 35" MTR's. 10-20=Can,NB,SJ. pics: http://www.flickr.com/photos/7439309@N02/ |
#6 (permalink) |
Bump...Any luck yet? Mines idling like a V8 with big cams, wifes got it today, hope it dont break down on her, love those calls at work.
__________________
#7 (permalink) |
Hey guys dont plan on really going over the truck for a couple of weeks yet but when I do I will surely let you know. I will FIND and FIX the problem. I hate when my motor doesn't run perfect. Anyone heard of a bad coolant temp sensor ever throwing those codes?
#8 (permalink) |
I have had bad evap can valves cause the rich/lean code C.F. you are describing. The engine will rich at idle and lean on cruise if the evap system is stuck on purge at all times. The Toyota EFI EVAP system is very simple at least on the 22R. The charcoal can has a system of check valves inside of it. Cap it off where it ties in the intake.
__________________
Dead: '94 2WD 22R-E 2nd Owner 9 years Bone stock DD except for: Clarion Head/Radio Crack Amp/coat hanger ant. Sunpro gauges. Undersized tires. (Forget the exact #'s) Red cockpit lights. (Always on.) |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| OBDII Trouble Codes | Bob_98SR5 | Maintenance & Repair | 0 | 01-14-2006 10:41 PM |
| Want to help me interpret these OBDII trouble codes?? | yoda-g2 | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 07-27-2005 08:09 AM |
| trouble codes help now what?? | 1987 street toy | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 12-05-2004 07:58 PM |
| Trouble. Reading Trouble Codes | evilcow | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 10-02-2004 08:05 PM |
| checking trouble codes | Robinhood150 | Maintenance & Repair Archives | 1 | 06-15-2002 01:58 PM |
