mrboyertown |
05-29-2007 03:36 PM |
All sorts of trouble codes Please Help!
I have a 94 Pickup SR5 V6 Automatic 200k miles. Iv'e been trying to diagnose a idle problem and excessive fuel consumption on my truck. At idle the engine has a slight lope to it. Sometimes it's worse than others but in either case its not a horrible lope. It holds a steady rpm at idle but the engine seems to shimmy. I tried raising the idle a little bit (it's already close to where it should be but figured raising it a little would help) but when i tried to increase the idle speed by turning the idle set screw i really didn't get much of an increase. I turned the idle screw all the way out and I couldn't get the idle to go any higher than 750rpm's in neutral and when the truck is in drive it's at about 650 to 700 rpm which makes the engine lope a little worse. Any idea why i cant get the idle speed any higher? Since I got the truck about 2 months ago I have had a few trouble codes but cant seem to figure out what would be throwing the codes and if it has anything to do with the engine lope and poor fuel economy. About 10-12mpg. First code thrown was 2-6(engine running rich) I figured it was the O2 sensor so i replaced it and reset the ECU. Started the truck up and the idle lope was still there and not but 100 miles later and engine light comes on again. The second time the light came on it was on for a day or two then went out for a while then came on again so I checked the codes again and this time I got a 2-5 and 2-6 (engine running lean, engine running rich?) now I am scratching my head. Running rich for a little than running lean? what could be making it throw both codes? O2 sensor new, MAF is working within parameters resistance wise, plugs-wires-cap-rotor all new and I have run all sorts of injector cleaner through it. Thinking maybe its the coolant temp sensor? Could that be throwing the codes? I reset the ECU to see if the light would come on again and it didn't for a week than it came on again. I checked the codes again and this time no 2-5 or 2-6 but now its 7-1(EGR valve exhaust temp not correct) what does that mean and do think that could be the problem thats making the engine run funny? In my FSM it says the 7-1 code is for California models only.....I live in PA but I guess I have a california model truck. Is that a good thing or bad? Overall the truck runs great, when going down the road you dont notice the engine lope and it doesn't hesitate at all. I do notice when I first start it in the morning you can smell the exhaust smells rich but no black smoke even when revving the engine at high rpm's. Im am lost as to where to go next and any bit of help would be appreciated. I dont want to just start replacing parts if I can help it. Sorry for such a long thread.
