Air/fuel ratio rich indicator
Old 04-12-2010, 09:22 AM
kyshooter's Avatar
I got a 26 code off jumper e-1 te-1. I am assuming this is an O2 sensor but I also have a couple of exhaust leaks. Should i start with the exhaust leaks or the O2 sensors.
Old 04-12-2010, 02:39 PM
Jay351's Avatar
If the exhaust leaks are before the o2 sensor then they will most likely be your problems. The o2 sensor will think the motor is running lean and will richen the mixture up. You can test the o2 sensor with a digital multi-meter.
Longbed 90
10-19-2015 11:05 AM
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
Aaronmarston
09-22-2015 09:39 PM
justdifferentials
09-05-2015 06:52 PM
Quick Reply: Air/fuel ratio rich indicator
