Adjusted valves, now ticks louder?
Old Nov 14, 2007 | 03:08 PM
Shoua's Avatar
My truck is a '91 with a 22re. I just finished adjusting my valves, and my truck runs a lot stronger, but the valve ticks at idle have gotten louder as well. Is this normal? I thought that adjusting valves made them quieter...
Also, I noticed that the passenger side idler arm has come into contact with my frame, not badly, but still. I've never noticed this before. Anybody know the cause of this?
Old Nov 14, 2007 | 03:13 PM
toy power's Avatar
as far as the valves, you've got to make sure that you havent overtightened the valve cover, as it will distort the rocker arm assembly and make the motor tick like crazy.. i know from experience.
Old Nov 14, 2007 | 03:21 PM
Shoua's Avatar
Is there a torque spec that I'm supposed to torque them to? 'Cause I torqued them to 10 ft-lbs.
Old Nov 14, 2007 | 03:30 PM
MMA_Alex's Avatar
not sure of the torque spec, but its basically just enough to keep it from leaking. I had my little rubber grommets wear out which caused it to either leak or be too tight. I can't remember how much the new grommets were, but it was under $5.
Old Nov 14, 2007 | 03:35 PM
Shoua's Avatar
Then maybe I'll just need to get new grommets. And I work at Toyota. Discount for me!
Old Nov 14, 2007 | 05:27 PM
MMA_Alex's Avatar
at the part store it was cheaper if you got the grommets & gasket together (like $1 more than just the grommets) so if you're gasket is looking shady you might as well jump on one of those too.
Mine was actually cut in a couple of places, and the PO just decided to tuck it back in, and hope it didnt leak too much...
JNapolitano
Nov 14, 2019 07:46 PM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
cars-guy
Jul 11, 2015 07:51 PM
Gamble_STi
Jul 7, 2015 07:54 PM
