AC Electric Fan Troubleshooting
Old 06-09-2007, 11:50 AM
DrAnonymous's Avatar
A/C Electric Condenser Fan Troubleshooting
I noticed my electric fan that's mounted on the A/C condenser doesn't ever seem to turn on. I know it should come on with the AC. Should it come on every time the clutch engages?
Thanks,
DrA>
Old 06-10-2007, 11:23 AM
Bumping this question.
I have discovered there isn't any mention of the A/C condenser fan in either the Haynes manual I have or the FSM. Its stock and sits right in front of the condenser.
Any info out there?
Thanks,
DrA>
Old 06-10-2007, 09:12 PM
MudHippy's Avatar
Shoot, let me bump this again here. I don't have a clue about it, nor can I find anything anywhere.
Somebody does, right?
Old 06-11-2007, 03:33 PM
MudHippy's Avatar
I found ya a thread to look at. That last post is interesting in particular.
https://www.yotatech.com/forums/f116/backup-radiator-fan-3-0-a-116211/
Old 06-11-2007, 03:59 PM
YodaPala's Avatar
What kinda rig ya got? Generally, if equipped w/ an electric fan it should come on when a/c clutch is engaged. (fan gets pwr from a relay) I'd say check and see if yer gettin pwr to the motor (fan) if not, relay might be toast. If there is pwr @ the motor you can check to see if it is bad by ohming out the motor winding w/ an ohm meter to see if there is any resistance. Does the motor spin freely? Hope this helps.
kawazx636
10-06-2021 03:03 PM
voiddweller
09-28-2015 11:21 PM
Matthew Perez
09-28-2015 05:43 PM
Project90
09-24-2015 11:40 PM
sonorn67
09-19-2015 05:39 PM
Quick Reply: AC Electric Fan Troubleshooting
