AC Condensation drip line under rig ?
Old 06-05-2007, 11:53 AM
keithguts's Avatar
OK I'm trying to clean out the tube where the water drips out from under the rig as I think it is not working. I only get a few drips from it after a long run. Last year I was having problems with water comming out from under the dash onto my feet.
I found the line, but it is not a little black hose. It seems to be a 1/4" pipe of some kind. I don't no, maby the hose came off. it has all little bends in it, and I can't seem to get anything up there pasted 1" or so. Any idears of how to clean out this line?
Thanks..............
Old 06-05-2007, 12:09 PM
keithguts's Avatar
anyone?
Old 06-05-2007, 12:36 PM
1styota4X4's Avatar
you may need be able to use compressed air (not sure never done it that way). In my old yota that I had to replace the expansion valve so i blew it out from the inside...there were lots of leaves and junk in there that allowed it to drain slowly
Old 06-05-2007, 01:03 PM
ewong's Avatar
I have a PORT AC so I dunno it it matches OEM (it should - it was dealer installed with Toyota parts)...
There is a ubber hose with multiple bends in it.
Its on the passenger side.
Mine hangs down in between the "loop" of brake line leading to the front /rear splitter T
I cleaned mine out from the INSIDE first (mouse nest... another story).
I have small hands tho and used a shop vac.
Take the blower motor out and then reach around.....
Blamalam
03-12-2022 07:34 AM
icentropy
09-16-2020 02:47 PM
coryc85
09-09-2015 06:24 AM
jackiebrownia
07-20-2015 09:02 AM
skoti89
07-08-2015 12:05 AM
Quick Reply: AC Condensation drip line under rig ?
