Abs Ecu
Old 02-26-2008, 02:01 PM
jason191918's Avatar
Abs Ecu
My abs light has been on since I bought my truck. I diagnosed the ECU as the culprit. Got a new one through Toyota and installed it. Problem not solved. Do I have to program it or something?
Old 02-26-2008, 02:18 PM
Elvota's Avatar
Do you mean you replaced the primary vehicle ECU?
What was your diagnosis process before replacement?
What codes did you have before, and what codes do you have now?
The ABS light is on steady, or blinking?
Old 02-26-2008, 03:13 PM
I replaced the ABS ECU.
I followed the diagnosis process in my chilton's manual.
The only code I had was 1 blink than solid, indicating faulty ABS ECU. This is the same code that I get now.
The ABS light still blinks once then stays on solid.
Thanks for replying.
Old 03-01-2008, 10:37 AM
anyone else?
Rerun
3.4 Swaps
10-01-2015 12:24 PM
bradahman
10-01-2015 09:24 AM
JimiJams
09-28-2015 06:14 PM
matt1833
09-16-2015 07:11 AM
zz_denis
09-06-2015 03:43 PM
Quick Reply: Abs Ecu
