A340H Park/Neutral Switch Inter-Year Compatibilty
Old 08-26-2015, 10:38 PM
Hugh_Mann's Avatar
I am in the process of replacing a dead A340H automatic transmission in my 1994 3VZE 4Runner. My donor transmission is from a 1992 3VZE 4Runner. Yesterday I discovered that the electrical connector for the park/neutral switch (pictured) is different. Apparently it changed for years 1994-1995.
Will I be able to swap the switch from my dead '94 transmission to the '92 unit without issue? I've searched the forums and haven't found an answer.
Thanks for your input!
Old 08-26-2015, 11:18 PM
AKHeathen's Avatar
try it and see. if it lines up with the shaft slot and bolt hole in the same place while in park, i don't see why it wouldn't work.
Old 08-27-2015, 11:07 AM
Hugh_Mann's Avatar
Yeah I'm thinking it will work too. I'll post my findings.
Old 08-30-2015, 07:36 AM
Hugh_Mann's Avatar
So it turns out the switches are backward compatible. I had no problem fitting the '94 switch onto the '92. Everything else was identical.
Glad to have this on record for anyone else searching the forums for an answer!
Old 08-31-2015, 04:02 AM
AKHeathen's Avatar
thank you for following up sir. i'm sure many will now find this even on a google search.
kawazx636
10-06-2021 03:03 PM
beltcutter
09-30-2015 06:14 AM
PNW94Runner
09-29-2015 02:55 PM
charlie_fong
09-27-2015 10:06 PM
runnermedic
13
09-21-2015 05:20 PM
Quick Reply: A340H Park/Neutral Switch Inter-Year Compatibilty
