A304H Temp Gauge an Filter Change
So two quick questions. First off I am going to be doing a Trans Filter and ATF change on the rig this weekend and what do you think about using AMSOIL? I can get it for about the same price.
And is anyone running a aftermarket temp gauge on this trans???? What one and where did you get it?
Thanks
Mike
Thanks
Mike
sounds good you should be fine with amsoil in the trans ive heard nothing but good things about the stuff. now the temp gauge the stock one should be fine but hey to each his own if you want to install an aftermarket one it should work if you install it right
the1998sr5
15
07-14-2020 08:35 PM
Poncho0206
07-10-2015 06:21 PM
